MOTU 828 Original and Thunderbolt 3
Hello,
I was not able to find this question posted elsewhere, nor on the MOTU FAQ page - I'm hoping to upgrade to a new macbook pro, which only has thunderbolt 3/usb-c ports. Is it possible to connect my 828 Original to that laptop. It is firewire 400 only.
I have heard some rumors that I *might* be able to use a thunderbolt 3 to thunderbolt 2 adapter, and then a thunderbolt 2 to firewire adapter, and then a firewire 800 to 400 cable to make it work...but thats like a lot of adapters to bank on before shelling out the money for a new laptop
Thoughts? Yes, I realize ditching the 828 would be an option but I'd rather not have to replace it.
Re: MOTU 828 Original and Thunderbolt 3
Thunderbolt contains just enough of the FW spec that most MOTU FireWire devices will work. USB-C is supposed to be backwards compatible with Thunderbolt 2/1. Bus power doesn't work due to the low power available but that's not an issue with any of the 828 units.
All MOTU FW devices are FW400 but the later ones have FW800 ports to eliminate the extra adapter—they're still FW400.
According to Apple, you will need a USB-C to TB2 adapter and a FW800 to FW400 cable for the most reliable connection. I've not met a 400-800 adapter that didn't unplug easily so I don't like them even though I have a couple.
I don't know that the 1st gen 828 will work but I see no reason why it shouldn't. If you had to upgrade to an 828 Hybrid or 828x, you'd be down to one cable, either a USB-C to USB 2 or USB-C to Thunderbolt.
- daniel.sneed
I still use my old reliable 828 original, with my 2015 MBP for some location trackings.
A FW 800 to 400 cable and a FW800 to TB adaptor at that's it.
Never a single glitch.
dAn Shakin' all over!
Has anyone heard if MOTU has plans to upgrade the 828 to output directly with Thunderbolt 3? I have the same issue as the OP in that I have a 828mk3 with FW 400 which in order to use a Mac with TB3 will have to go through a cadre of adapters to work. As long as I can get this to work I will but I'm loathe to purchase a 828x only to see an upgrade to TB3 come out in a couple of months.
iMac (Retina 5K, 2017) 4.2 GHz Intel Core i7 running 10.13.6 / 64GB RAM 2400 MHz DDR4/ DP 9.52 / Cubase 10.0.15 / UAD Apollo x8p / MOTU 828es / MOTU 8pre / Mackie 1604VLZ4 / Yamaha S80
If that is going to happen, it will be announced sometime around Winter NAMM. Then we will all know. Not holding my breath.kemccarthy1 wrote:Has anyone heard if MOTU has plans to upgrade the 828 to output directly with Thunderbolt 3? I have the same issue as the OP in that I have a 828mk3 with FW 400 which in order to use a Mac with TB3 will have to go through a cadre of adapters to work. As long as I can get this to work I will but I'm loathe to purchase a 828x only to see an upgrade to TB3 come out in a couple of months.
- ggm1960
I can report that connecting an 828x to a 2017 MBP with Thunderbolt 3 using an Apple adapter definitely does not work and has left me in a rather desperate situation.
MBP's, DP10, 828x's, MTP's
https://www.facebook.com/Meinfield-346702719450783/
I can run my original 828 on my 2013 MacPro using a TB 2 to FW 800 adapter and a FW 800 to FW 400 cable. I did, however, have to install this: MOTU Audio Installer 1.6 (83634).pkg. This works in Mohave and Catalina. I haven't tried this with TB 3 and adapters or with Big Sur.
