I read on a truly ancient thread here that if you use USB for both BCF2000 units, then it is easy to have CueMix treat them as two separate control surfaces. For some reason daisy-chaining via the 5-pin DIN does not work.apanacci wrote:I have actually 2 MCU controllers. An older one and a newer one. I tried hooking up the old one for CueMix and the newer one for ProTools. As soon as I select the newer one in ProTools the MKIII goes nuts! The older MCU is connected via MIDI to the MKIII and the newer one is connected thru its USB port to my MAC. When I try that configuration in DP , both the MCU,s control CueMix. I cannot seem to separate them. I have tried different MIDI channels for the controllers, does not work.
Terry
