Traveler Mk1 Headphone out problem - sum of L & R -ve feeds
Studio 96
Post by Studio 96 »
Hi everyone,
I have the original Traveler and have recently noticed when trying to record vocals, that the headphone out is not giving me true L R channels, but is stripping out the vocals. From experience this sounds the same as 'stereo difference' i.e. when the -ve feed from both channels are put to a single speaker and the vocal is stripped.
I'm using Sierra, with Logic Pro X, on a TB to Firewire lead. All other inputs and outputs appear to be performing as expected, and I have the Phones assign to Output 1 - 2.
What's also odd is that my little foster desk monitors, connected to output 1-2 on balanced jacks from the MOTU, have a headphone jack which performs as expected. I have reset to the default so don't believe I have any funny mix presets going on. Has anyone else experienced this from the MOTU or from the Mac?
Thanks,
Andrew
Re: Traveler Mk1 Headphone out problem - sum of L & R -ve fe
Sounds like the tip and ring are shorted out. It could be a very minor mis-alignment. You might be able to fix it with a small dowel or toothpick. Maybe a good cleaning will do the trick. If none of the above, then you might need to replace the jack.
Studio 96
Post by Studio 96 »
Thanks cuttime - much appreciated - when checking the T/R I tried another 6.3 - 3.5 adapter which has done the trick! Simple things... should have checked first. Thanks for posting and glad it's fixed..!
