Hi everyone, you guys are one of my last hope
I have this old 828 motu audio interface and up to recently, it's always been of great services but lately, I don't know why, this happens each time I launch any audio software : I have incredible distorted signal coming out from outputs 1 and 5 and SPDIF out led is on (which I don't know if it's supposed to be that way or not.. can't remember) even when nothing is playing or when no session is open in any software I use (digi perf mostly).
Even if I launch Garage Band I get the problem. Do you have any idea where the problem could be coming from ? This is so annoying and frustrating. Thank you.
A smile,
Sëhb.
Old 828 - weird problem
Re: Old 828 - weird problem
Try resetting to the factory default.
http://motu.com/techsupport/technotes/reset
Voltage Reset: To perform a voltage reset, power the unit down and disconnect all cables. On the right side (the depth) of your unit, there is a red voltage selector. Toggle this switch back and forth several times, and be sure to reset it to the correct voltage .... Power the unit back on and test.
Hi there and thanks for trying,
I did try your suggestion not really believing it would do anything (sorry) but... what have I got to loose ?
Well, it didn't work.
Crap, I think I might have to get a new one...
After 15 years (at least) of very good services... impermanence.
Yea, it was worth a try but, as you've pointed out, these are quite old. The newest builds of the mkII (like mine) are now over 9 years old.Sehb wrote:Hi there and thanks for trying,
When one channel goes out, that's not a good sign.
You can try opening it up, burning the internal connectors by unplugging and reconnecting each three times. Can't hurt but probably won't help, either.
