Os version pole
- supersonic
Os version pole
I was curious what are numbers on that. I am using Mac OS X Yosemite 10.10.5
Music is movement in silence
Re: Os version pole
10.10.5 here as well.
Not exactly loving it. Since 10.6.8, each OS has been some mixture of taking the good with the bad. For the all their concentration on new features, some apps (iCal, Mail, Preview, Safari, etc.) get messed up or workflows get unnecessarily cumbersome. Now I'm so reluctant to update until I know just what kind of hassles I'm signing up for. And there's MUCH less confidence that Apple will ever fix things-- why would they? when a new OS is only ever months away.
Re: Os version pole
10.10.5 on three Macs, 10.6.8 on one, and 10.8.5 on one.
- supersonic
Re: Os version pole
Same here. I feel there is space for a very stripped down system version that could be installed for a DAW only computer that would certainly make things way more efficient. I should think the studio computer should be rid of all the externalities. Just the barebones needed to run a killer solid Production DAW station.stubbsonic wrote:10.10.5 here as well.
Re: Os version pole
As per sig... 10.8.5
HC Markus
Re: Os version pole
10.11.6 and I'm staying there indefinitely for my Mac Pro.
It's a heavily modded 2009:
new 3.33ghz 12 core chips,
internal AHCI main 512GB m.2 SSD,
NVME 512GB SM951 m.2 that only works with a third party "generic" NVME driver someone coded for fun. Apples NVME driver only works for authorized (sold by them) m.2 cards.
Sonnet PCIe USB3 card
Taking the chance that the NVME drive made by someone on a forum stops working in Sierra on my 09 mac pro that doesn't meet Apples "recommendations" or the USB3 stops working, just for the ability to have iOS content? not a chance in hell.
Re: Os version pole
10.11.6 and I still keep 10.6.8 around for Rosetta. Not itching to go any further at this point, but I may when the coast is completely clear.
- Robert Randolph
Re: Os version pole
10.11.6 and very happy with it.
Best OS X since 10.6.8 for me. In fact, I still have 2 systems in my workshop on 10.6.8 because it's so trouble free.
Re: Os version pole
10.11.6 and 10.12 on a test drive. I'll update my system as soon as I have tested a few more things that I mentioned in other threads.
Re: Os version pole
Hehe, now I feel older than .... I am
10.7.5 here, but only because Behringer ( Midas ) devs said, more than 16 ch USB recording
can't be done reliably in 10.6.8 ( core audio ? )
Is 10.6.8 really that bad re : USB ? Or could this be related to USB hardware in older Macs ?
Anybody - MotU ? - can confirm this ?
Editing / mixing in the studio - USB playback - on a Mac Mini 4,1 - 10.6.8.
with no problems
Best regards from Switzerland
Klaus
with no problems
Klaus
- Robert Randolph
Re: Os version pole
Yes, older versions of OS X had difficulty when developers tried to use USB polling rates higher than 125hz. It could cause jitter in the polling routine that is very difficult to get around. This was noticeable with some USB interfaces, and very obvious with certain 'gaming mice' that would have very poor response with >125hz settings. Certain medical devices also behaved very poorly as well due to this.Klaus wrote:Hehe, now I feel older than .... I am
with no problems
Klaus
Later versions of OS X behave much better with higher polling rate devices. It's basically not an issue anymore.
Re: Os version pole
Thanks a lot Robert !Robert Randolph wrote:Yes, older versions of OS X had difficulty when developers tried to use USB polling rates higher than 125hz. It could cause jitter in the polling routine that is very difficult to get around. This was noticeable with some USB interfaces, and very obvious with certain 'gaming mice' that would have very poor response with >125hz settings. Certain medical devices also behaved very poorly as well due to this.Klaus wrote:Hehe, now I feel older than .... I am
with no problems
Klaus
I have since not had any samples dropped with 10.7.5...
but sometimes the SSD ( EVO Pro Samsung ) via USB mini plug ( USB powered ) doesn't mount stable...
Best
Klaus
Re: Os version pole
Three Mac Pros here:
10.10.5
10.9.5
10.8.5
I have no plans to change any of that.
10.10.5
10.9.5
10.8.5
Re: Os version pole
10.11.5 and holding indefinitely unless i absolutely have to update for a DP upgrade on DP X (DP 10).
- supersonic
Re: Os version pole
Hard to keep track of all those versions!!! Is there a pole function I could enable in the forum?
