I have quite a few ADAT devices and would like to use a 112d as a hub to mix and route them, is there any way to convert the DB25 AES/EBU to ADAT as well?
thanks!
is there a product to convert the AES/EBU on 112d to ADAT?
Re: is there a product to convert the AES/EBU on 112d to ADA
If you have a breakout box or cable, there are a few that convert aes/ebu XLR to ADAT optical.
http://www.sweetwater.com/store/search. ... &Go=Search
I use this. Or I should say, used to use this. Dont have the need anymore. It is in pristine condition in it's box and available if you can't find anything else to buy. Contact me off list if you need to.
RME ADI-4. DD 8-Channel 24-Bit/96kHz Dual Universal Format Converter (ADAT, AES-3 and S/PDIF)
