Hi All,
After having many problems with my old Motu UltraLite, it eventually broke, and I sent it off and got a replacement "Hybrid" model.
When connecting this to my Macbook Pro 2012 Retina model, I've been getting noise and hissing and very unstable behaviour. So I followed the instructions to update the firmware, hoping it might hep things. I installed firmware v1.06, and the install appeared to work ok, but now when it turns on it shows Meter 44, with the "44" flashing continuously. No sound is coming out.
Is this a hardware fault? Did installing firmware onto my device break it?
I then tried to reset it to factory defaults. It still seems to load with "v1.06", and the 44 is still flashing.
Is there any way I can revert to my prior v1.03 firmware? or do a more full reset? Any suggestions? It would be a crying shame if this is the second unit to die on me, this one has had a grand total of probably 5 minutes play time.
Any help would be greatly appreciated.
UltraLite mk3 Hybrid. Installed v1.06, Meter 44 now flashing
- terrybritton
- Primary DAW OS: Windows
Re: UltraLite mk3 Hybrid. Installed v1.06, Meter 44 now flas
Go into the Motu Audio Console and check that you do have it set to internal sync (or set that up from the front panel if you can find the window). It sounds like it cannot find a device it is trying to sync to.
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Looked this up...cause I'm having the exact same problem, same error code. Sent it back to Motu...just got it back and it's doing the same thing. I've sent in a tech link...but looking for help here.
