ok so all of the sudden today - mac doesn't see my 896 or the 828 ? I can't help but think it's El Capitan OS ....but it worked last week !! Had to download for Final Cut Pro to work ....normally I would wait to download new OS but needed.....
tried drivers / unplugged & voltage reset .....???
thanks in advance
Mac not seeing 896 / 828 MKll ... El capitan?
Mac Pro 4,1 2.66 GHz Quad Core, 16GB Ram, OSX.7.5, Dual Cinema Displays -ATI Radeon 5770, Motu 896/828MK II DP 8, Waves v9
Re: Mac not seeing 896 / 828 MKll ... El capitan?
Your FW port may have crashed. Reset the NV RAM and see if that helps.
https://support.apple.com/en-us/HT204063
its all working now but I have no idea why! El Capitan has given me nothing but problems so far Thanks
I had a problem like this yesterday, my first boot with El Capitan and a Traveler connected to a FW hard drive. On boot, it automatically opened MOTU Audio Setup because it sort of? saw the Traveler, then reported "no MOTU hardware present". On starting DP 9, the Bundles window saw the inputs and outputs of the Traveler, communicated with them fine, and I could record to the FW hard drive downstream from the Traveler.
However, in Hardware Audio Setup the Direct Hardware Playthru option was greyed out, and I couldn't use CueMix FX to control the Traveler.
So, I suspect that the MOTU driver that has been updated for OS X 10.11 may have some glitch when it comes to legacy hardware interfaces. It could also just be a startup glitch in my system after doing a whole bunch of OS and software updates.
I'm going to try again today, and will try my new 896 Mk3 Hybrid on both FW and USB ports as well.
Mike, was it you who wrote that Apple and Intel had some kind of conflict that was affecting the stability of FireWire?
MacBook Pro 9,1 (mid-2012 Core i7 2.3 GHz 4 GB RAM), OSX 10.11.3, Newertech Voyager SATA drive dock
MOTU: DP 9.02, Traveler Mk 1, 896 MkIII Hybrid, MIDI Express XT
Alesis AI3 optical interface, QS8, QS7, DM Pro, DM5, QSR
Mackie Controller and Extender (original MIDI)
Pro Tools 12
Pro Tools 12
Not quite that simple. FireWire was a protocol fully supported by Apple and the PPC Consortium.Mike, was it you who wrote that Apple and Intel had some kind of conflict that was affecting the stability of FireWire?
Some of the protocol works on Intel Macs, enough for Apple to still support it. Less of the FW protocol works over Thunderbolt. If TB does not pass certain parameters, than the TB-FW adapter can't either.
If using a third party FW adapter such as a PCI card, make certain that it has a Texas Instruments chip set. These work better. More of an issue for Windows but the same applies to the Mac.
Well, I tried again, this time connected via USB to an 896mk3 Hybrid. Same story: the interface works, but MOTU Audio Setup sees it as a generic device, so CueMix and direct hardware play thru don't work. I have MAS set to start whenever it sees an interface: odd, that MAS starts during boot up, then says "No MOTU devices found"...
This is on a MacBook Pro 2012 that still has FireWire ports, so I'm not going thru Thunderbolt.
Maybe I should have checked Audio MIDI Setup, but since audio was working fine I didn't think to. I just opened a Techlink with MOTU on this.
Pro Tools 12
Pro Tools 12
