PCIe SSD drives
PCIe SSD drives
Hey guys, anyone out there have one of these or have any info, thanks !
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Re: PCIe SSD drives
A PCIe blade is the fastest drive you can install in a MacPro unless you have one of the early ones with limited PCIe speed.
Not cheap. When you consider that you can get a 2T SATA SSD well under $700, a PCIe blade might not make sense.
The speed/performance bump between an HHD to an SSD at 3G speeds will be far more noticeable than the bump between a 3G SSD and a PCIe blade.
Although the bus speed on a MacPro is limited to 3G, you can double it to 6G by buying an SATA PCIe card. That will allow any SATA SSD to run at max speed. As fast as a PCIe blade? No but the bang for the buck is pretty good.
