Hello motu users !
I need some help to configure outputs in CueMix, using a 828mk3 Hybrid..
All my Mac sounds and DAW comes to Main Outputs and it works well, but I want to root the same signal to analog 1&2 outputs too. (so I can filter both speaker pairs individually).
Had trouble clicking the "monitor" button, volume became very loud it scared the f* out of my s*, so I'm a bit stressed everytime I click somewhere now...
Thanks to helpers out here
Need help for 828mk3 routing in CueMix
Re: Need help for 828mk3 routing in CueMix
My understanding is that the 828 will mirror main 1-2 outputs with analog 1-2. What I've done with my 828 is set the OS output to spdif and loop the 828 spdif out to the in and then you can mix the OS signal with any of the output busses, main 1-2, analog 1-2, analog 3-4 .... adat A 1-2 ....etc....
I've tried this and it works perfectly!
