SSD drive methodology.
Henry Robinett
Post by Henry Robinett »
So I guess I've got to start thinking about this. I've always used the four drive bays as
HD 1: OS and application, documents and iTunes, samples for Kontakt, etc.
HD2: backup of HD 1
HD3: DP and other audio projects.
HD 4 back up of HD3
It's worked well. I have other drives connected via FireWire or USB I can offload to. All the drives are 2TB. They back up every night with SuperDuper.
Obviously if I go SSD I'll just put the OS and apps on it (HD1) and everything else goes elsewhere. That means my back up drive won't be an SSD. I can back it up to an external drive, or just have a smaller internal HD 2 to back it up, put all my documents, iTunes (huge), and DP audio on 3/4.
What do you guys do? Just thinking out loud. I'm reconfiguring. I upgraded the CPU and memory of a MP. Still having some issues related, I'm sure, to not doing clean installs. So I figure I really just need to bite the bullet, take a couple of weeks, no doubt, and slowly reinstall all my software. ARGGH.
All the best,
www.henryrobinett.com
Check out my latest CD on iTunes.
I Have Known Mountains by Henry Robinett
https://itun.es/us/pi6C_
All the best,
Henry Robinett
2019 Mac Pro 16 core, 192 GB; 2 MacPro 5,1 Metric Halo ULN-8 3d (x6), ULN-2-3d, MIDI Express XT,
DP10.13, UAD2 Quad TB,Duo,solo, Fractal Ax Fx III, FM3, LF+12+, Altiverb 7, Pianoteq7, Falcon, Keyscape, Omnisphere, Kontakt 5, Superior Drummer 3, Slate Drums, Live 10, Battery4, Diva, Spitfire Chamber and Symphony Strings, Ivory 2, Spectrafoo, Millennia HV3-D, many mics, many guitars . . ..
Re: SSD drive methodology.
I use multiple drives for Time Machine. One local, two remote. Works great, invisible and does not conflict with any process my Mac is using. and Apple always updates it with the OS.
Do not use SSDs for archival and backup.
3-6tB HHD drives are cheap and readily available. Avoid Seagate unless you want to join the class action suit over the (non)reliability of their drives.
Henry Robinett
Yeah, no SSD for archive. I should use Time Machine, but I don't.
All the best,
All the best,
Henry Robinett
OS and Applications, and all sessions work and VI sample sets reside on SSDs. My SSDs were purchased when capacity was limited, so there are five of 'em… one in an OWC SSD drive sled and four sitting in the optical bay on top of the (unused) lower bay optical drive. Two of the four are connected to the SATA ports in the optical bay. A SATA3 Pie card hosts the remaining two. Trim is enabled (I'm running Mountain Lion) using Cidnori's Trim Enabler.
I archive at end of day to two internal spinners. Time Machine is always running in the background on one of two USB2-connected external HDs just in case, and I rotate the Time Machine drives on and off site every week or two for disaster-proof backup.
Optical drive is a BluRay burner in an external Firewire case that sits on my desk. The Computer and everything else is in the machine closet, out of sight and sound.
HC Markus
