Correctly linking a 16A and a 24Ao??
nickbaba
Post by nickbaba »
I'm looking into getting a 24Ao to add to my 16A, to expand my analogue outs.
I'm confused about linking options - my 16A is connected to my MAC by Thunderbolt. In the manual it says I can link my 16A and a 24Ax via the ADAT optical, or via an ethernet cable.
16A only has 2 ADAT i/o of 8 channels each - so that's a max of 16 extra channels.
1) If I use an ethernet cable to link them via AWB, will I then be able to use all 24 extra outs?
Do I also still need to connect the channels by ADAT optical? Or is the ethernet cable all I need to use the extra 24 outs?
2) Does the AWB link only work under OS X Yosemite (and above)? Or is that only if I need to connect 1 interface directly to my MAC via AWB?
The manual isn't very clear on this.
Anyone know?
Thanks.
nickbaba
Re: Correctly linking a 16A and a 24Ao??
Post by nickbaba »
D'oh - I mean AVB, not AWB, of course.
it's late here...
EMRR
Post by EMRR »
AVB via ethernet is best.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
nickbaba
Post by nickbaba »
Thanks Doug
So I only need the AVB connection (and D-subs) to access all 24 extra outputs?
