Hello!
I receive this error code in Logic when trying to work with Motu Traveller:
Error code 4 in file firewiredevicelmpl.cpp line 399 called from file I_fwaudio.cpp line 2188
My system is:
Macos X 10.10.5
MacPro early 2008
2x2.8 Ghz Quad Core Intel Xeon
6GB DDR2 800mhz Fb-dimm
Startup disk: MacPro SSD
Ati Radeon HD 5770 1024mb
Audio Device concerned:
MOTU TRAVELER 192 SERIAL NUMBER: TRAV000435
Can you please let me know how to overcome this problem? I cannot use the device this way, I am getting broken signal while trying to record or capture.
Thanks a lot! Waiting for a solution!
Getting Motu error code 4 for firewiredevicelmpl.cpp
Re: Getting Motu error code 4 for firewiredevicelmpl.cpp
Usually Error 4 means that something cannot connect. Sometimes, it means a corrupt file or driver. I have heard of it being a permissions issue, too.
Logic is not giving you this error. The OS is.
My first thought is to make certain that your FW connections are tight. Next, I would make certain that you have the latest driver installed. Repair permissions.
If neither of those do it, time to post a Tech Link with MOTU support.
Are you running any 3rd party utilities on your drives?
