MTP AV appears a new device every session
I can't figure this one out. I'm using OSX 10.10.5 and Digital Performer 9.01. All drivers are current version as of 9/25/2015. The Mac is a 2009 Mac Pro and the MIDI interface is a MIDI Timepiece AV (USB).
Every time I start the Mac Pro Audio MIDI Setup creates a "new" device for the MTP AV (named MIDI TimePiece AV #2, #3, #4, etc.). The new MTP AV is active but not connected to my other devices, and the old one (connected to my other devices) is inactive and greyed out.
After I reconfigure Audio MIDI Setup by connecting my other devices to the "new" MTP AV, everything works fine until I shut down. I've done a hard reset on the MTP AV several times but it didn't resolve the problem.
Has anyone else encountered this? Thanks!
- FMiguelez
Re: MTP AV appears a new device every session
Replace the unit's battery.
And while you are at it, replace the battery in your Mac Pro. They each take a CR2032, available just about anywhere.FMiguelez wrote:Replace the unit's battery.
OMG - Thank you.. I have been trying to figure this out now for 4 months. It started for me when I updated Cubase 6.5 to 7.5 and then to 8 Pro. I have been beating up Steinberg about it for months and they do not have a clue.. So simple except that I will need to take about 6 hours to rip apart my studio just to get at both MTPAV's to replace the batteries, but that makes plenty of sense.
THanks SO much
THanks SO much
HP Pavillion DV9500T, 4 gig Ram, Dual 20" Display, 512Mb Nividia 8600 video, 3 SATA HD 7200 RPM 520 Gig max. Cubase VST, SX and 4.02, Halion3, Grove Agent 2, Virt Guit, EWQL Sym. Choir, Voices of Pass, NI Kontakt 2 Kore, Giovani Edition, DIVA, Melodyne Studio 3.2, BFD
Roland JV, XP, D, XV series synths, Korg TR, Triton, O3R/W, M3R, MTPAV (2) USB, Ultralite, Mackie 8 Bus, HUI.
Yikes! Fortunately, when you remove the covers, you will see the batteries immediately.
Again, replace the one in your Mac Pro at the same time. That battery will say BR2032 if it's still original but a CR2032 works just fine (only the 2011 and later iMacs and the 2013 Mac Pro need a BR2032 due their internal heat).
Thank you! It worked.
Corollary to this (and thanks for mentioning the iMac having the battery) how do you know when to replace the battery? I know the symptoms to look for with the MTPAVUSB having one of my own but don't know what to look for for the iMac?mikehalloran wrote:Yikes! Fortunately, when you remove the covers, you will see the batteries immediately.
