Hi,
I'm having issues with my setup here.
I have 2 usb MTP AV's and 1 old Timepiece (the first one) and a serial MTP AV.
I have them setup as networked MIDI interfaces.
The Usb MTP AV with the old timepiece is behaving perfectly!!
The other networked setup, the usb part works perfectly.
Only the networked interface behaves strangely.
When playing a chord sequence through the ports on the mtp av (non USB), notes get stuck and also sometimes even transpose like errors.
I tried the setup while disconnected from the computer (as networked MIDI router). I used an external sequencer to send out MIDI data through the motu's.
Even then the old MTP AV behaves strange.
What can this be?
Has anyone here had this problem and found a way to fix this?
Thanks in advance!
Motu MTP AV Usb and serial problem
Re: Motu MTP AV Usb and serial problem
What's your setup?
What is the firmware on the MTP AV USB?
