Removing all MOTU drivers and software from Mac OSX
Guys,
I cant find info anywhere on removing MOTU files from OSX completely, please advice.
Thank you!
Thank you!
Re: Removing all MOTU drivers and software from Mac OSX
That covers too much ground. Do you have a particular product in mind?
For DP and Audio & MIDI Interfaces:
~Applications (ClockWorks, CueMix FX, MOTU PCI Audio Setup, DP and MOTU VIs that run stand-alone)
~Library/Application Support/MOTU (tonnes of stuff in here involving DP's plugs)
~Library/Extensions (Motu MIDI Driver, MOTUFireWireAudio, MOTUMicroBookAudio, MOTUPCIAudio etc. post-Mountain Lion)
~Library/Audio/MIDI Devices (MOTU ƒ)
~Library/Audio/MIDI Drivers (Motu MIDI Driver lives here)
~Library/Audio/Plug-Ins (MAS ƒ)
~Library/Audio/Plug-Ins (MOTU Audio Export ƒ)
~Library/Audio/Plug-Ins (MOTU Control Surface ƒ)
User/Library/Application Support/MOTU (This is for CueMix Configurations and some of DP's plug settings)
User/Library/Preferences (just look for files and ƒs starting with com.motu.xxxxx - they're all grouped together)
User/Library/Audio/Presets (MOTU folder can be removed if there)
If you've installed purchased MOTU VIs or plugs:
~Library/Audio/Plug-Ins/Components (if you chose the AU option in the installers, otherwise they'd have been in the MAS ƒ - see above)
~Library/Application Support/MOTU (I'm guessing this is where support folders would live)
Post-Mountain Lion the extensions, as listed above, are in ~Lib/Extensions.
Pre-Yosemite, they're in ~System/Library/Extensions, and they begin with "MOTUxxxxx"
This covers pretty much all of it, excepting for invisible files such as "Auth" ones, which can't do any harm and occupy a ridiculously-small amount of disk space.
How soon we forget.This covers pretty much all of it, excepting for invisible files such as "Auth" ones, which can't do any harm and occupy a ridiculously-small amount of disk space.
http://www.motu.com/techsupport/technot ... issionsFix
OK, it's only still an issue if you have Auth files predating DP 5 and are trying to authorize DP 7.24 or earlier.
A few years back, I posted a better fix than the one in the Knowledge Base that works on all versions of OS X including Yosemite. If it's ever needed, I can find it or post again.
Thanks guys. Its just any files left by installing the current drivers for an 828 mk2
This is what MOTU sent me for my 828mk3 Hybrid. I think it is the same for all units:
Macintosh HD/Applications/:
CueMix FX.app
MOTU Audio Setup.app
MOTU PCI Audio Setup.app
MOTU PCI SMPTE Setup.app
MOTU SMPTE Setup.app
Macintosh HD/Library/Audio/MIDI Drivers/:
Motu MIDI Driver.plugin
Macintosh HD/System/Library/Extensions/:
Motu MIDI Driver.kext
MOTUFireWireAudio.kext
MOTUMicroBookAudio.kext
MOTUPCIAudio.kext
Macintosh HD/Library/Extensions/:
MOTUPCIAudio.kext
Macintosh HD/Users/YOURUSERNAME/Library*/Preferences/:
com.motu.ChannelNamerAwesome.plist
com.motu.CueMixFX.plist
com.motu.firewire.SMTPE.console.plist
com.motu.FireWireAudio
com.motu.pci.config.console.plist
com.motu.pci.CueMix.console.plist
com.motu.pci.SMPTE.console.plist
com.motu.PCIAudio
MOTU FireWire Console.prefs
Macintosh HD/Users/YOURUSERNAME/Library*/Application Support/MOTU/:
CueMix FX
* To access this folder, click on the Go menu in the Finder, hold down the Option key, and select “Library”.
10.10.x = Root Library for Extensions
Anything before = System Library for Extensions
Hope this helps!
CueMix FX.app
MOTUPCIAudio.kext
MOTUPCIAudio.kext
com.motu.PCIAudio
CueMix FX
Hope this helps!
Looks like MOTU just copied me. LOL
Trust you to have found a better solution than the one in the KB. Amazing!
I hadn't forgotten, Mike, but all indications were the OP hadn't been using DP for that long. If he / she had been doing so, he / she'd have had a much better idea of where to look for the files, you'd think.mikehalloran wrote:How soon we forget.This covers pretty much all of it, excepting for invisible files such as "Auth" ones, which can't do any harm and occupy a ridiculously-small amount of disk space.
