I bought a brand new Motu Ultralite AVB today, as an upgrade for my beloved Motu Ultralite MK 1. I use Mac OS X (Yosemite 10.10.3). I installed the latest drivers and upgraded the firmware without problems.
I'm having an issue related to Inputs-Outputs naming in DP8: I don't see the description of each channel as I did before with my Motu Ultralite MK 1 (which previously stated for example "Analog 1", "Main Out 1-2", "Phones", etc).
Instead of this, I only see them as "Audio In 1", "Audio In 2", etc... I want to properly see what kind of channel they are, like what I see in the Routing tab ("Mic 1", "Mic 2", "Guitar 1", "Guitar 2", "Main LR", "Analog Out 1", etc)
This is both when using the interface connected thru USB or Ethernet.
I'm uploading two screenshots that may clarify what I mean:
Does anyone know how can I rename the channels so I can work the way as I'm used to?
Alan
Ultralite AVB Input and Output naming
- alansende
www.cromomusica.com - DP 11 - Macbook Pro M2 Max 96GB Ram 2TB - Focal Trio 6BE - Avalon 747 - Universal Audio - Audient ASP800 - TC Clarity M - NI Komplete Kontrol S61 MKII - Kemper Profiler - Fender Rhodes MKI 1977 - Moog Slim Phatty - Moog Subsequent 37 - Prophet Rev 2 - DSI Mono Evolver - Fender Am Std Tele - Fender Am Pro Strat - D'Angelico Deluxe Bedford P90 - Ibanez JSM10 - Fender P Bass - Fender Mustang Vintera - Beaudoux PA1 - Taylor GS Mini - Zaor, Mixingtable & Raventos Design
Re: Ultralite AVB Input and Output naming
You can rename them in the bundles window if renaming in the AVB window doesn't transfer over.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
