Please help with my motu!!!!!!!!
Hi i,m from spain
It's been a couple of days since we tried to work the 24i/o in conjunction with PCI424.
We followed the installation process for mac and this is what we've got so far:
Upon clicking:
MOTU PCI AUDIO SETUP : Configure Interface "BLANK", Audiowire - "0" no inputs or outputs enable i can,t open interface options i can,t do Nothing
MOTU PCI Cuemix Console: no available
MOTU PCI SMPTE Nothing
But when trying to access MOTU Audio Setup, Cuemix Console and SMPTE Setup... Nothing,
We have tried using the firewire cable that came along with the package and tried two other brandnew firewire cables with the same Results i tríed to install first the drivers again ,(without pci 424 installed) installing later the pci 424 .......and nothing,,, i tríed to do the Same in a pc(with another pci 424 card) and nothing too.
The manual gives just a simple instruction to install first the driver for PCI424 prior to the installation of the PCI Card
The MOTU 24I/O displays a continuous blinking of Clock at 44.1kHz.
Help guys!!!!what can i do more??????
my 24 I/O interface is dead?????? :
Best regards
edu
Upon clicking:
Best regards
edu
Re: Please help with my motu!!!!!!!!
OK, the AudioWire cable supplied by MOTU isn't a FireWire cable (AW precedes FW by a few years). You should notice that the metal part of the connector is a tiny bit longer when compared to a FW cable. If not, make the connector about 3mm longer by removing insulation on the plug with a knife or razor blade – do both ends. The longer connector is the only difference, by the way.
If that doesn't do it or you can see that one is definitely an AudioWire cable...
Did you buy this used?
What Mac are you trying to install it in? Be very specific.
Is the card a 424, 424x or 424e?
http://www.motu.com/techsupport/technot ... patibility
Thanks Mike for your help!!!!!!
The firewire cable It,s The original(comes with The 24 I/O)
The same cable could open in my mac an external hard drive(recognised,open and works ok)
I tríed to install Again and Again The drivers (first drivers without The pcix 424 card,and changing The card in various slots.......and nothing
The cuemix console doesn,t appear, 0 inputs and 0 outputs enabled. I can,t open interface options,i can,t enable nothing
Sometimes said something like........ (General window) "launch with motu when hardware are available" and of course The neverending blink of 44.1 led in 24 I/O interface!!!
My Mac It,s a PowerPC G5, macosx 10.5.8
A month ago everything works ok!!!!!!!!! I don,t know what can i do more........
Maybe buy another audio FireWire cable????????
Try to open The 24 I/O and check something????????
Buy another interface?
Thanks a lot for your help!!!!!
Yup, my first thought exactly. The 'puter isn't seeing the interface, and a dodgy 2nd-hand AudioWire cable is the most likely culprit.
Mike's advice is brilliant. Modifying a FW cable at least saves you the wait for a proper AudioWire one and gets you up and running for now. Even if your mods don't work for some reason (contacts not quite making the distance required for connection being the most likely), I'd still wait and see if a proper, new AW cable does the trick. Almost certainly this is the issue.
The lights are blinking 'cause the unit can't sync its clock to the PCI card, again, 'cause there's no connection.
Thanks mr. Monkey man ¡!!!!!
I,ll wait for another cable....and i try to do with a normal fw cable Mike,s modification too
You fixed The same problem with another cable?????
Thanks!!!M!!
Thanks!!!M!!
No, I've never had any issues; the units are rock-solid, mate.
This sort of cable confusion has arisen (appeared) from time to time 'though. Many people have wrongly assumed it's a Firewire cable, which it almost is, but it's not. It's a proprietary (unique to MOTU) format. This is why it's better to get a "proper" one than to modify a FW one - if problems occur in future (which they should not!), at least you'll know it's not the cable.
Good luck, Guitarreiro.
Thanks !!!
But......i must buy an audio FireWire cable? Or look for an original motu cable(i don,t know if exist in my country)????
Thanks mr.monkey!!
Thanks mr.monkey!!
The distributor for your country will have AudioWire cables. You can email MOTU for contact information if a Google search doesn't produce that result faster.
Ok mike!!!!! Thanks for your help!!!!
I,m Going to look in Google .......
I reread your OP and saw that you are in Spain which shows up on this list:
http://www.motu.com/other/distributors.html
Yes i know mike!!! I,ve tried past friday to speak with The distributor here in Spain, but nothing .......always no one at phone!!!!
I,m trying to Send an e-mail
Who knows, maybe it,s time to change my recording system.........maybe another motu card and interface ..... Or change to protools or something......
Thanks for your patience!!!!
Naaa... stick with MOTU, mate!
Just keep trying. They'll answer the 'phone eventually.
Remember, it's not an audio firewire cable you want (there's no such thing). You want a MOTU AudioWire cable.
Hi!!!!!
I,m still waiting answer ...........
Things here are slow!!!!!
3days ago and no answer jet !!!!!!
They told me"i,ll give you a answer (type of cable,and number reference )very quickly........."
My god!!!!!! I don,t want info, i want to buy it!!!!!!!! I want to check if The cable are wrong or The interface are broke....
Ha ha ha! You're so funny, Guitarreiro. Reading your posts makes me laugh.
Hang in there mate. Be patient. Keep trying. They'll have to give in eventually, no?
I don,t know.........
This evening nobody knows nothing........
maybe I ask for work at the customer service department
perhaps it would be better their attention
Best regards from spain
