get return on Ultralite Hybrid MK3 analog outs to main out.
espressif
Post by espressif »
Hi all,
The proprietary audio software I use has no matrix capability and I'm trying to get a return from 8 analog out to main mix. There seems to be no "dry" send/return path in Cuemix to do this (such path is only possible via the reverb).
The only solution I found is to physically connect each analog (1-8) outs to an "y" to get outputs *and* analog ins (1-8) and use the Mixes to route each analog inputs to the main. Sure, there is a risk of feedback if the Mixes are misconfigured (say, for example: Analog in 1 routed to Analog out 1).
Any better idea? Sure I could add an external mixer for this task, but i prefer to avoid it.
Thanks for your help (btw, sorry if I miss something obvious, but I read the manual many times...).
Ultralite MK3 Hybrid, Macbook Air i7 1,8 GHz, Yosemite, Qlab V.2
Sony Vegas/Sound forge (on Bootcamp).
