Hello all.
MOTU will not output audio. We did have a power outage here, but MOTU is surge protected.
1. At first, MOTU had disappeared from Logic input and output option in Preferences>Audio. I reinstalled drivers, which did not help, and then re-set PRAM which caused MOTU to reappear in Logic.
2. Unit will still not output sound. Everything within Logic appears as normal. However, on MOTU front panel, lights are indicating output signal on outs which ought not have any, and no signal on the only outs which should.
Am I cooked? Thanks for any ideas.
MOTU 828 mk3 Hybrid and Logic Pro 9
iMac 4G ram 10.7.4 828mk3 Logic 9.1.7
Re: MOTU 828 mk3 Hybrid and Logic Pro 9
Solved.
Everything in Logic was not correct. Re-setting the PRAM seemed to have reassigned outputs in Preferences. Duh.
