Hi,
I want to use the CuemixFX Software to submix my Keyboardrig. I've a Yamaha S90ES connected via Audio to my UltraliteMK3 and a Keyboardcontroller connected to Mainstage via USB. The S90ES is not connected to Mainstage.
What I need is an Output from Mainstage to CueMix, but can't find a way to do that. Is this possible? Tanks!
Routing Mainstage Output to CuemixFX
Gear: Ultralite Hybrid Mk3
Re: Routing Mainstage Output to CuemixFX
hi
Unfortunately you can't do this.
Cue Mix is inputs mix only. You can't see the internal audio stream from any software (main stage, logic, DP...etc).
hope it helps
hope it helps
