Hi,
I recently added a MOTU audio express. When connecting a mic to it (via Mic/Inst 1), and then into DP-8 via USB, I noticed the mic is always 'on' and able to receive input, even when the DP track select/rec enable button is not engaged. I didn't use to experience this with my 828 mk2.
Probably something really basic I am missing, but between DP, CueMix and the audio express unit itself, I can't find a way of muting the mic for playback. Am I missing something?
Many thanks in advance!
Roger
Microphone muting (DP/Audio Express)
Re: Microphone muting (DP/Audio Express)
Do you have the Audio Input Monitor button turned off? Or, if on, is the mode set the way you want? See manual p 217.
Yes, I tried that. It is not muting the mic, even if the track is not record-enabled. Thanks for trying.
Try muting it in Cuemix? The signal will still get to DP.
Hi again,
Nope. Tried that. The CueMix track mute, even the master track mute, makes no difference. I had wondered whether it was to do with 'Audio Patch Through' on DP, but it doesn't seem to work either. Right now all I can do is unplug the mic...hardly practical!
Maybe time to go to tech support
