My Microbook II now has extremely low output on computer generated sources. Aux 1-2 and Mix 1 in cue mix show very little signal even when maxed out, but no noticeable distortion. The mic pre has plenty of volume, but intermittently generates white noise and/or severe distortion, which resetting to factory default seems to cure, but then it returns.
I don't think it's a problem with the USB bus from computer, but I don't have any way to test it.
Any suggestions?
thanks in advance
Low output and distortion on mic pre, microbook II, resolved
iMac 2.66 GHz Intel core 2 duo, 8 gb ram running 10.11.6; 17" Macbook Pro 8,3, 2.5 GHz Core I7, 16 GB ram running 10.13.6; DP 8.07; 8pre-es; 828mkII; 828mkI; microbook II, Behringer ADA8000, Black Lion Auteur 2-Ch. Pre-Amp
Re: Low output and distortion on mic pre, microbook II, reso
Got a new one from MOTU. Thanks MOTU!!
