My Ultralite started having intermittent power issues. So I took it apart, looked inside and I noticed the power connector is split in half. Also I noticed some cracks on the adjacent MIDI connector.
Would be nice to have a replacement power board, as it doesn't look too good.
It should be like $2 worth of parts, and no more than $5-$10 bucks for the whole board.
MOTU Tech Support charges a flat fee of $99+shipping to have it fixed. Of course they are.
Obviously I'm looking to find a more convenient way. Any ideas?
Ultralite MK3 Hybrid - power connector broken
Re: Ultralite MK3 Hybrid - power connector broken
Find the components yourself on DigiKey and replace them yourself. $99 probably looks reasonable now eh?
How handy are you with the soldering iron? You could hard-wire the power supply in without much trouble. Or, as suggested, go the Digi-Key route and find and replace the stressed parts.sidney wrote:My Ultralite started having intermittent power issues. So I took it apart, looked inside and I noticed the power connector is split in half. Also I noticed some cracks on the adjacent MIDI connector.
I've repaired many pieces of gear over the years. Visual inspection, as you have conducted, will often revea the source of problems. Spend a few hours, learn a few things, and (probably) save a lot of dough.
