It is currently Mon Oct 10, 2016 11:21 am
Text Size
HELP!! Ultralite / USB / droput / no sound
Postby tomascoox » Sat Jun 14, 2014 7:05 am
Hello,
Yesterday, it happened. That one thing which can not happen.
Big stage. Big crowd. Famous swedish artist. Slow ballad with only artist and me on piano AND fat backtrack.
Right before first chorus. ZIP!!! And then no sound. Band had to jump in and do a stripped down version of the song. Baaaad....baad....bad.
Not a good day in my career. :(
Here's what the console spits out when this disaster happened.
2014-06-14 00:50:18,000 kernel[0]: IOAudioStream[0xffffff80504c4000]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (3c31,184)->(3c34,4a4).
2014-06-14 00:50:18,000 kernel[0]: IOAudioStream[0xffffff80504c4000]::clipIfNecessary() - adjusting clipped position to (3c34,184)
2014-06-14 00:50:18,000 kernel[0]: IOAudioStream[0xffffff80504c0000]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (3c31,184)->(3c34,4a4).
2014-06-14 00:50:18,000 kernel[0]: IOAudioStream[0xffffff80504c0000]::clipIfNecessary() - adjusting clipped position to (3c34,184)
2014-06-14 00:50:18,000 kernel[0]: IOAudioStream[0xffffff80504c0400]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (3c31,184)->(3c34,4a4).
2014-06-14 00:50:18,000 kernel[0]: IOAudioStream[0xffffff80504c0400]::clipIfNecessary() - adjusting clipped position to (3c34,184)
2014-06-14 00:50:18,000 kernel[0]: IOAudioStream[0xffffff80504c0800]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (3c31,184)->(3c34,4a4).
2014-06-14 00:50:18,000 kernel[0]: IOAudioStream[0xffffff80504c0800]::clipIfNecessary() - adjusting clipped position to (3c34,184)
2014-06-14 00:56:30,000 kernel[0]: IOAudioStream[0xffffff80504c4000]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (5108,188)->(510b,4dc).
2014-06-14 00:56:30,000 kernel[0]: IOAudioStream[0xffffff80504c4000]::clipIfNecessary() - adjusting clipped position to (510b,188)
2014-06-14 00:56:30,000 kernel[0]: IOAudioStream[0xffffff80504c0000]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (5108,188)->(510b,4dc).
2014-06-14 00:56:30,000 kernel[0]: IOAudioStream[0xffffff80504c0000]::clipIfNecessary() - adjusting clipped position to (510b,188)
2014-06-14 00:56:30,000 kernel[0]: IOAudioStream[0xffffff80504c0400]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (5108,188)->(510b,4dc).
2014-06-14 00:56:30,000 kernel[0]: IOAudioStream[0xffffff80504c0400]::clipIfNecessary() - adjusting clipped position to (510b,188)
2014-06-14 00:56:30,000 kernel[0]: IOAudioStream[0xffffff80504c0800]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (5108,188)->(510b,4dc).
2014-06-14 00:56:30,000 kernel[0]: IOAudioStream[0xffffff80504c0800]::clipIfNecessary() - adjusting clipped position to (510b,188)
2014-06-14 01:34:35,000 kernel[0]: USB Sound assertion in AppleUSBAudioDevice at line 286
Can someone please help me set my computer straight.
Regards,
Tomas Coox
Ultralite Mk3
MacBook Retina i7 SSD
Mainstage 3.0.3
Ultralite directly into the left USB port
Keyboard and AKAI Pad via a DRBot USB 3-way hub on the right USB port.
tomascoox
Re: HELP!! Ultralite / USB / droput / no sound
Postby chapelierfou » Wed Aug 20, 2014 8:50 am
Hi,
i am having the exact same issue with a 828x. I bet you are on Mavericks, aren't you ?.....
Bad news, according to Motu support, the only way is to downgrade to 10.8.
Which is not an option for me.
Motu support tells me to contact apple support, but come on.... my RME UCX and my Presonus FP10 are just working perfectly.
Did you contact the support ? The more "complaints" they have, the more likely they'll fix it quickly...
chapelierfou
Postby tomascoox » Wed Aug 20, 2014 12:15 pm
Hello,
I'm on a downgraded (10.8.5) machine now since a couple o' weeks and can't be happier.
Furthermore, this problem has finally been aknowledged by MOTU and they are working with Apple to solve it. I hope it will be part of a new MOTU-firmware for Yosemite.
I had to downgrade because that was the only way I could go out gigging without being totally terrified onstage.
Cheers,
Tomas
tomascoox
Postby chapelierfou » Thu Aug 21, 2014 12:51 am
Yeah, that's a shame...
btw, downgrading implies a fresh install, doesn't it ?
chapelierfou
Postby tomascoox » Thu Aug 21, 2014 2:40 am
Yep, formatted system-drive and clean fresh 10.8.5 install. Then installing all that I needed fresh. 10.8.5 feels snappier too. I'm just…happy and can concentrate on what I should concentrate on. :)
tomascoox
Postby chapelierfou » Thu Aug 21, 2014 3:37 am
Well, i might consider doing it as well after all....
thanks
chapelierfou
Postby tomascoox » Thu Aug 21, 2014 3:47 am
Good luck! :) Right now it will be the best spent hours you can spend. :)
tomascoox
Return to MOTU Hardware & Mac OSX
Who is online
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 4 guests
Who is online
In total there are 6 users online :: 2 registered, 0 hidden and 4 guests (based on users active over the past 5 minutes)
Login Form
