Hello everyone,
I'm kind of new in the asking question in forum area. So don't hesitate to tell me where to go if i'm misleading.
Anyway, i'm gonna have a 896MK3 tommorow, and i wanted to know if i could change the output level reference on the eight anolog (+4 / -10) like we used to be able on a 896HD.
All of my material is based on +4dbu, and i'm affraid of this +19level would put the mess in my monitor configuration.
Thanks for taking the time to answer, i can't find anything in the manual.
A new member of the motu community
Motu 896MK3 Output level
Re: Motu 896MK3 Output level
Welcome! By now you've gotten your 896 and know the answer to your first question...no, it doesn't do -10 (dBV) level outs. (I thought the -10/+4 was only on inputs in the old days?) I'm not sure if using it unbalanced would lower the level to -2 dBu, though.
But you should know that the "+19" spec you read refers to the maximum output level, not the nominal. It is +4, with 15 dB of headroom...pretty standard.
BTW, don't make the mistake of lowering the MAIN output level of the 896 to like -20 or -30 for everyday use, while leaving your monitor amps wide open. It's better to set the MAIN control (Left/Right outputs) between 0 and -6, then tweak the input sensitivity of your monitors so they give you your customary SPL (85 dB) with a typical signal. Less noisy, better resolution, less chance of blowing something up.
MacBook Pro 9,1 (mid-2012 Core i7 2.3 GHz 4 GB RAM), OSX 10.11.3, Newertech Voyager SATA drive dock
MOTU: DP 9.02, Traveler Mk 1, 896 MkIII Hybrid, MIDI Express XT
Alesis AI3 optical interface, QS8, QS7, DM Pro, DM5, QSR
Mackie Controller and Extender (original MIDI)
Pro Tools 12
Pro Tools 12
