I tried to get the most info in the title as possible b/c i did a search myself and had trouble finding the answer.
I had a windows setup way back with these same two devices that when I FW-chained the orig 828 to an mkii I would get 22 i/o (or 16 I don't recall but it was both)
But now I'm on Mavericks OSX and using ableton (64bit) and when I chain the 828s I have to choose between either interface as the input or the output instead of them acting like one interface. Not good. Although it would be interesting if I could load a 32 bit version of ableton and use both soundcards at once.
**the mkii is v1.01 firmware
-appreciate any insight.
Orig 828 FW chained to a mkii and i have to choose i/o dev?
Re: Orig 828 FW chained to a mkii and i have to choose i/o d
Read about setting it up as an aggregate device - this gives you one large device with all of your I/Os.
Or you can use a hub to run the two as separate devices.
Thanks Mike, that's done the trick. Not vibe-ing w/ OSX yet but its only been a month. Now to integrate my Motu MIDI XT.
