Hi!
I'm having a hard time finding a straight answer to this on the MOTU website: If I upgrade to a new MacBook Pro which has no Firewire port, will I be able to reliably run my Motu 838 MkIII (firewire only, not hybrid) interface with DP 8 on the new machine by using an Apple Thunderbolt to Firewire Adapter, or is there any other recommended adapter that works better?
Anyone using these? Thanks!
Doug
Motu 828 MkIII firewire with Thunderbolt adaptor?
- FutureLegends
Re: Motu 828 MkIII firewire with Thunderbolt adaptor?
My 828mk3 works great with my rMBP using the FW-TB adapter!
looking at buying new MacBook Pro. Can I run the original MOTU 896 using the thunderbolt to firewire 800 adapter connected to a Firewire 800 to 400 cable? Thx!
Can you confirm that the original 896 works? I have to help a friend setup a new system. My plan is to use a FW400/FW800 cable and the TB adapter to his new iMac. If you have the 896 working -- what driver version are you using on your system? Thanks.rigsbalicious wrote:looking at buying new MacBook Pro. Can I run the original MOTU 896 using the thunderbolt to firewire 800 adapter connected to a Firewire 800 to 400 cable? Thx!
27 inch iMac 3.6 GHz Intel Core i9 40GB Ram - macOS Sonoma 14.3.1
Logic Pro X 10.8.1 - Performer Lite 11.23 - LUNA 1.5.3
Apollo X6 - UAD 11.1.0 - UAD OX 1.2
There are reports that the 1st gen 896, like the 8pre, will not work with the TB-FW adapter. Best to ask MOTU directly.Can you confirm that the original 896 works?
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.4, USB4 8TB external, M-Audio AIR 192|14, Mackie ProFxv3 6/10/12; 2012 MBPs Catalina, Mojave
Did you get a reply to your question? I have a similar question if you look in the hardware/windows forum. I'm thinking that it is only possible with Cuemix (and maybe the 828) to mix inputs onto a bus and send the bus out to the mains or the phones. You can't do this with outputs, unless I am missing something that you are trying to do.
You can check out our latest 1z0-050 practice test - pass4sure.co.uk and IBQH exams written by our certified teams to help you pass Rockefeller University .
