Cable for Playing Videos using DP and a Mac Pro
by xsound » Mon Jun 25, 2012 11:12 am
Greetings,
Is the Firewire port on the Mac Pro the one used for playing videos from DP? or is it the Mini DVI one? What cable should I use? If you have a link or recommendation please let me know.
Thanks in advance
Thanks in advance
- xsound
Re: Cable for Playing Videos using DP and a Mac Pro
by MIDI Life Crisis » Mon Jun 25, 2012 1:47 pm
Currently Firewire to a Firewire video device (not direct to a monitor) but in DP 8 that should change. What version of DP are you currently using?
_______________________________________________________________________
_____________________________MIDI Life Crisis_____________________________
_____________ML.3 • DP 64 bit • 8 core MP/20GB RAM • Track 16______________
MIDI Life Crisis - Posts: 17797
by xsound » Tue Jun 26, 2012 8:16 am
Thanks for the reply. I am using 7.2. Is there a cable that does the conversion to DVI?
I need to send video out from DP to a projector.
- xsound
by MIDI Life Crisis » Tue Jun 26, 2012 8:30 am
Without a video converter that is not currently possible as far as I know. A Canopus box will run about $100. It's not something a special cable can accomplish.
by xsound » Tue Jun 26, 2012 8:48 am
Do we know when DP8 is coming out?
What are going to be the advantages of using this boxes once DP8 is out?
- xsound
by stephentayler » Tue Jun 26, 2012 8:49 am
Currently DP can only output full frame DV (standard definition) video through firewire to either a DV card (Canopus) or through a DV camcorder - if it has a firewire connection. These then connect to a screen or projector through standard video connectors.
You can connect a second screen or projector to your Mac through the usual monitor outputs.... but your video will be in a quicktime window (with it's borders) in DP, which is OK for working to picture, but not so good for display.
However, when DP8 arrives, you will finally be able to present a full frame movie on any screen connected to your mac - through DVI or HDMI..... just set up the projector as a second screen for the Mac.
I do this at the moment with dedicated video playback software synced to DP.... I connect the DVI output on my Mac to the HDMI input on my 50" plasma..... and the Mac recognises it as a second monitor.
But it will be nice when I can do it all in DP!
Cheers
Stephen
Cheers
Stephen
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Mac Pro 8 Core 2.8Ghz 16Gb RAM, MacBook Pro, 2Gb RAM, OSX 10.8.2, DP 8.01, PT9.06, Logic 9.1.8, MOTU Traveler, Ultralite Mk 3 Hybrid, MC MIx, MOTU VIs, Waves, Izotope Everything, Spectrasonics, SoundToys, Slate, Softube, NI Vintage Compressors, spl Surround Monitor Controller, spl Auditor Headphone amp, Genelec 1031A, 1029 5.1 system, Sontronics Mics, iPad etc..
stephentayler - Posts: 2270
• Page 1 of 1
Return to MOTU Hardware & Mac OSX
Who is online
Users browsing this forum: No registered users and 3 guests
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
