The meter in CueMix FX reflects the onboard DSP resources of the audio device, not the computer CPU. Is that where youse guys are parting ways?Klaus wrote:You can watch the CPU meter going up when enabling ADAT...in Motu Audio Setupnarrenschip wrote:I wouldn't expect that. Can you elaborate?Klaus wrote:
and using ADAT i/o does eat CPU
Klaus
As I understand, the PC/Laptop is only controlling the audio interface with CueMix Fx. There's actual no audio transfer to/from the PC/laptop. Adding ADAT pre-amps to the audio interface doesn't change that.
If you enable ADAT A and B - In and Out, you may run into trouble enabling a lot of EQ / Dynamics
Best
Klaus
Controlling Cuemix FX and outputpairs?
Re: Controlling Cuemix FX and outputpairs?
DP8.06 PT11.2.0 VEP 5.3.x
My bad... I should have written DSP... yes the box's DSP, not the 'puter
Sorry, just came home from setting up the X32Core with 3 clients / faderboxes...
and enjoying no DSP problems...
http://www.redmountain.ch/x32coretouchbcf2000.jpg
Recording with DP 32 tracks at the same time > ( back on topic - almost )
Best
Klaus
Best
Klaus
Ah, that explains it. I didn't notice any sudden spike in DSP use when enabling the ADAT ports. Just the DSP monitor going up for each channel where I enabled EQ/dynamics.Klaus wrote:My bad... I should have written DSP... yes the box's DSP, not the 'puter
I think that as long you don't need the built-in reverb, there's enough DSP power available for EQ and some compression on 16 in and 8x2 out.
Nice setup. I've been looking at the Behringer X 32 Rack, but can't justify the cost. Traveller + ADA8200 + old Macbook + old wifi router + ipad will have to do.Klaus wrote:Sorry, just came home from setting up the X32Core with 3 clients / faderboxes...
