Hello
I used and still use a motu 2408mk2 with osx 10.4.11 cue mix 1.42 / pci audio setup 1.31 without problems.
since last week I use the 2408mk3 with osx 10.4.11 cue mix 1.42 / pci audio setup 1.31
why I can hear the stereo output of the analog inputs on tdif channel 1+2??? My 2408mk2 don't do that??
Any suggestions? Maybe internal problem of motu 2408mk3? or is it normal??
thnaks for your help
2408mk3 analog inputs on tdif output??
Re: 2408mk3 analog inputs on tdif output??
Hello
after the post I have solved the problem. Tdf outputs were enebled at cuemix!
Now smt. else appears: I have a synth. connected to the analog inputs 1+2 of the 2408mk3. On cuemix I'dont see any input signal on analog 1+2 instead I have input signals on 5+6+7+8?????
what I'm doing wrong??
Hello
problem solved. After removing cue mix 1.42 and reinstalling ver.1.4!!!
Think it was the same problem as here: http://www.motunation.com/forum/viewtop ... ix#p267358
