cuemix fx + bcf2000?
Re: cuemix fx + bcf2000?
Well plugging them in separate USB ports works fine, they come up as two devices, and then you define what group and group position using the BCF keys just like you would if you were using one unit.
You just have 2 BCF's and you can select whatever group you want. You could use them for input 1-8, input 9-16, outputs etc, even change them on the go.
It works wonderfully.
I guess you could have as many as you have USB ports.
But with daisychaining, (plugging one into the MIDI IN/OUT of the other) they appear to MOTU as one device.So if you select outputs on one BCF, the faders on both units move round to be the output faders. It's like they are an exact mirror of each other.
I'm using Mackie - Mackie control.
Not sure what the 'expanded' means
In Apple's Audio MIDI setup,wayneconnor wrote:I'm using Mackie - Mackie control.
If I use Mackie control instead of Mackie control expander, I get the *channel 1 at - 24.1 dB* syndrome on all mixes...
It is described here on the forums but I can't remember where
Klaus
Hi guys,
could anyone here that has a bfc2000 take a look at my thread here:
http://www.motunation.com/forum/viewtop ... =2&t=42303" onclick="window.open(this.href);return false;
I'm trying to ascertain whether or not it can control the talkback in Cuemix.
http://www.motunation.com/forum/viewtop ... 00#p368629" onclick="window.open(this.href);return false;
( more than 8 stereo mixes... )
Klaus
Klaus
Please< help. I cant focus on 4,5,6 etc channels, only can focus on 1,2 and 3 channel when i using FLIP. What im doing wrong??( Win 8x64, bcf2000) Sorry for my English
Sorry, Macs here...
Best luck
Klaus
Best luck
Klaus
SOLVED!! Problem was on the controller side, i try with new same controller and all works fine!
