How to stream S/PDIF output from other Device
- Primary DAW OS: Windows
Hi All,
I am trying to stream Ultra lite mk3 S/PDIF output from other device but didn't see any data when recording from Audacity .
I have made following connections.
Ultra Lite mk3 S/PDIF out --> My device S/PDIF in
My Device S/PDIF in will go to one of Output device
While recording the stream from my Output didn't see any data.
Please see below settings for MOTU Audio Console
General Settings
Sample Rate --> 44100
Samples Per Buffer --> 96
Master Clock Source --> Internal
UltraLite mk3 Hybrid
Phones Assign --> S/PDIF 1-2
Main Out Assign --> S/PDIF 1-2
Return Assign --> S/PDIF 1-2
General Settings
- terrybritton
Re: How to stream S/PDIF output from other Device
Please reword your request for info. You seem to have your "from" and "to" items mixed up here, so I really cannot follow what it is you are trying to do at all.
For instance, your first line seems to be ACTUALLY saying you want to stream FROM the 828 S/PDIF TO another device.
Edit needed!
Terry
Edit needed!
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
- terrybritton
Additionally, you did not mention if you are using Cuemix and whether you are familiar with how it works or not.
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Thanks for your reply Terry.
I have installed Cuemix software but i am newbie to MOTU Ultra Lite MK3 so i am not sure how cuemix works.
Actually my connection is like this
Ultra Lite Mk3 S/PDIF Out is connected to Other Device S/PDIF in. For this case Please tell me the proper settings in Cuemix as well as for MOTU Audio console.
- terrybritton
You make one of the 8 MIXES point to the S/PDIF output. (In the final slider's drop-down menu you select the destination for that mixer.) Then you enable the channels you want to send to that slider. Pretty easy once you get that you have 8 separate mixers assignable to 8 separate output destinations available in Cuemix. Watch your mutes! (Yellow means muted.)
I hope that explanation coupled with the video clarify that for you.
Most important item for the MOTU Audio console is to have the sync set to "Internal". Set the other external device's sync to "External" so it slaves to the MOTU box.
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Hi Terry,
I have gone through the video provided by you. And I have made settings as per my requirement. I am able to see the S/PDIF output in Cuemix meters tab.
The output of S/PDIF is given to another device of S/PDIF input. The another device actually sends that S/PDIF in to one of Analog out put of that device. But I am not able to listen any audio from that analog output. Does this mean my code is not working properly or am i missing anything?
I am not able to attach the screen shots of cuemix software settings.
- terrybritton
If you are seeing output in the meters (the last slider especially) in Cuemix with the S/PDIF output selected and it is connected correctly, then perhaps the other device is not sending out its analog output, or is exhibiting some incompatibility. Does it have meters to view? It might be helpful to me to know what this "other device" actually is.
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
