monitoring analog outputs 828x
I can't seem to find a way to listen to music from my computer, whether streaming or from my own collection, via the analog outputs. I want to send that signal to a different room/amp/speakers while I listen to the same feed via the Main 1/2 outs. I have tried everything I can think of, read every bit of the manual but nothing works. I'm using Cuemix to do the routing since this doesn't involve a DAW. On my Widows 10x 64 computer I tried changing the default listening device to Motu Analog vs. Main 1-2. I tried using the 5.1 setting in the monitor control. Tried setting a mix on bus 1 as the output pair, 5+6 in this case. Nothing ever shows up at the outputs. What the heck am I missing?
