Amplifier power cycle crashes MOTU UltraLite mk3 Hybrid
krista
Post by krista »
Took me a while to figure this out, but if I power cycle my amp, an Adcom GFA-535ii, it will cause the UltraLite to stop responding to the PC, until I power cycle the interface.
This doesn't happen every single time, but will happen within 10 cycles, even if the power change has a 10 second delay between all event.... usually it occurs within 5 cycles.
This didn't happen with the m-audio the UltraLite replaced.
This seems to be happening with the Adcom amplifiers connected to my other interface, the 896mk3 Hybrid, although instead of *just* not playing audio, the computer will stutter on video as well, and requires a *computer* reboot, instead of just an interface reboot. I'm still testing this case.
While I'm bitching:
On both setups, and testing on Win7, Win 8, Win8.1, Win 10, and Win 10 Anniversary, enabling "WaveRT" playback in the Motu Audio Console causes corrupted audio during a long playback session, usually within the hour. The corrupted audio is recognizable, although it becomes worse at fixed intervals which seem to be at an integer multiple of the time it takes to originally corrupt.
Higher data rates seem to cause this corruption quicker: 2 channel 44.1khz takes around an hour, 2 channel 96khz seems to take around half that. High bitrate 7.1 surround corrupts well under half an hour.
A fix requires some combination of rebooting the computer, rebooting the interface, or occasionally can be fixed by restarting the driver by changing bit rates and changing them back.
As a programmer, this is screaming it's a corrupt circular buffer somewhere in MOTU's driver. This glitch fails to occur with any other WaveRT device I've had access to.
terrybritton
Re: Amplifier power cycle crashes MOTU UltraLite mk3 Hybrid
Post by terrybritton »
krista wrote:While I'm bitching:
I un-check WaveRT, but the WDM bugs in the MOTU audio drivers re-emerge no matter what hoops I jump through. The ASIO drivers are stable. (Have 828 mk3 hybrid and Ultralite mk3 hybrid).
I solved all my issues by turning off the MOTU Audio completely in the device manager under Sound, Video and Game Controllers, and use Voicemeeter Basic (and sometimes Voicemeeter Pro) as my default playback and record interfaces for general Windows audio, sending to the ASIO MOTU drivers via that.
I have two large-ish posts on that topic here and here.
Terry
MOTU 828 mk3 hybrid
terrybritton
OR you can jump into this thread at Head-Fi for two pages of reading (and perhaps backtrack to #23) and see how others have suffered ... I mean ... tried to solve this!
Terry
MOTU 828 mk3 hybrid
