Help! Different 24i/o and Windows 10 issue
Phdamage
Post by Phdamage »
Been having a helluva time with this. I install the drivers, then physically install the 424 pci-e card. If I attempt to switch to motu pci asio in cubase, I get the following message: " asio cannot use this motu pci configuration because no outputs are enabled." I follow the prompts to enable the outputs but the drop down menu I would normally use to enable them is empty. Any ideas?! Was really hoping to have this working to start a mix on Wednesday.
I've tried uninstalling and reinstalling, tried switching ports, tried switching pci slots. Nothing works. The Motu audio console tells me 0 ports are enabled but I have no idea how I can change that.
alexg1200
Re: Help! Different 24i/o and Windows 10 issue
Post by alexg1200 »
I am having the exact issue and same exact error with my HD 192 and now 828mk3. I am running windows 10
AMD 3.5ghz 8 core Processor 3.5ghz
16gb ram
64bit
I go to the PCI audio control and not able to select and thing or load interface configuration.
