Hello everyone. Thank you for accepting this forum.
I have a question for you.
For many years use MIDI Timepiece AV (no USB, which came with RS242)with Cakewalk.
After a few years, I decided not to continue using the computer to sequence so make setup with hardware sequencer (Kawai Q80).
I have not the RS232 cable to routing MIDI data in PC mode.
Im try it in stand alone mode, by the LCD Screen.
In the IN1 connected to a Roland XP10 to make master controlling.
IN2 to the output of the sequencer.
And in the Outs I have:
Out1: Korg Poly 800 (in channel3)
Out2: Yamaha DX7 (in Channel2)
OUT3: Casio CZ1000 (in channel1)
OUT4: Korg M1 (in channel 9 to 11)
OUT5: Kawai Q80 IN
I want to IN1 and IN2 sends the signas to Out1, Out2, Out3, Out 4 and Out 5.
Try to routing by LCD screen (looks very simple) but it is totally impossible for me to make it work.
Can you help me?
Thank you!
Midit Timepiece as Stand Alone
Re: Midit Timepiece as Stand Alone
The MTP can be used as a standalone device but cannot be programmed in standalone mode.
You must program and store your settings to the MTP while hooked up to a Mac or PC. Those can now be accessed while in standalone mode. The manual is fairly clear but you must learn to use the same terminology that MOTU uses.
