MOTU 16A Low recording levels
PeterH
Post by PeterH »
I'm experiencing very low recording levels into my DAW (Sonar Platinum).
For example I have connected my Line 6 Helix into the Audio Interface and using zero latency monitoring. I find that I have the Helix cranked flat out and even then the level isn't very high.
Am I doing something wrong? Is there a setting to "lift" the input levels? I tried upping the trim settings but there's no difference.
Thanks in advance.
Cheers
Peter.
rean1mator
Re: MOTU 16A Low recording levels
Post by rean1mator »
curious as to whether you figured out what the problem was. I"m having the same issue. I can get a proper level to my monitors with some addition of compression setting on the avb mixer but when I record to ableton the recorded level is very low.
some gear is worst than others. my dx200 and an200 are extremely low. elektron gear not as bad but still low. I have post process and normalize all my recordings. I saw another post on here during my google search with the same issue.
Anyone?????
Bluenote
Post by Bluenote »
Moin,
Open motu 16a control software. There you find input settings and the trim setting for the inputs. All Inputs are a bit trimmed.
Grüße
