Hi All !
Some questions for the gurus here .. about the RS-422 net cable..
1. what is the pinout of the Motu "net" cable ? (RS-422) Google-ing I got a confusing result, and even on Motu.com, it shows that RS-422 is a 9-pin connector
http://www.motu.com/video-products/v4hd ... erm=RS-422
(scroll down to the very bottom of the page), which looks preeeetty much like the old serial port connector (that's RS-232 if I remember well).
I've found a pinout, but from this I can't yet solder a cable, I'm afraid.. or at least, some advice would come handy..
https://opengear.zendesk.com/entries/21 ... tor-pinout
Furthermore, another article that I found,
http://electronics.stackexchange.com/qu ... for-rs-422
says that different websites state different things.. :-/ (scroll down almost to the bottom.)
Has anyone ever (successfully) home-made a motu net cable ? Where can I find instructions / drawings ?
2. What's the (official, and/or slang) English name of the connector which is Motu's net connector ? (Yes, I know, RS-422 .. but, does it have any other name on the market, in other products, other applications ?) In other words, how can I find (and order) such a connector (or ready-made cable), for instance in Radio Shack or other similar shop ? (Motu doesn't seem to sell such cable.. https://www.motu.com/store/accessories )
On Wikipedia I found that RS-422 https://en.wikipedia.org/wiki/RS-422 is actually NOT the name of a connector, rather it's a standard, that "specifies electrical characteristics of a digital signaling circuit. Differential signaling can transmit data at rates as high as 10 Mbit/s, or may be sent on cables as long as 1500 meters."
Aaaanyway.. the point is, how can I either make, or order such a "net" cable ?
RS-422 cable for Motu net
Re: RS-422 cable for Motu net
From MOTU:
The V4HD provides comprehensive video and audio synchronization features, including time code I/O, video ref with loop through, large front panel time code readout and RS-422 (Sony 9-pin) machine control.I would think that Markertek would be your best source for such things. If you are doing video and don't know them … well, you should.
http://www.markertek.com/
RS-422 is a standard and, as is illustrated on the other link, the wires carry different signals. Does it mean that you can use a common RS-432 cable? Apparently not as Markertek sells a 432-422 adapter.
http://audio-video-supply.markertek.com ... sitepref=1
I have not worked in a TV studio in over 20 years. My knowledge on the subject is rusty at best, behind the times is far more accurate.
See:
https://photos.google.com/photo/AF1QipM ... boZvYssEER
for a diagram that I use to connect V4HD to JVC BR-S822U.
Best,
Kent
Best,
Kent
