Dear Motuheads,
first of all sorry for my ultra beginner question!
I'm usually using a different interface brand and a friend has provided me
his Ultralite MK3 as a backup system for several upcoming shows.
I'm setting it up and have two problems/questions.
I cannot reach him and the manual is super big. So I hoped you could quickly
chime in and help!
1. How can I route Ableton OUT 1/2 to MOTU Analog OUT 1/2?
At the moment I think Ableton OUT 1/2 goes to MOTU MAIN OUT, while Ableton OUT 3/4 goes to MOTU Analog OUT 1/2.
2. How can I change Output Volumes (or actually see signal movements) in CueMIX? No matter what I do (sound is heard), theres nothing happening in there? Do I need another software? I'm very used to RME's Total Mix so I'm a bit lost here.
Thanks a lot!!!!
Tobi
Beginner Question: Routing and Volume
Re: Beginner Question: Routing and Volume
I'm sorry you're not getting any help here. I'm a mac user so I can't help you.
Hopefully some windows user will jump in and give you some advice.
Perhaps by now you've cracked open the f'n manual and have figured it out.
Also on a Mac...
Here is where you can download the manual in .pdf. Unlike the paper one, this file is searchable which should help.
http://www.motu.com/techsupport/manuals
This does require drivers. You want the latest MOTU Audio Installer for Windows.
http://www.motu.com/download
Just seen this. I suspect the OP has figured it out for himself by now but for the benefit of future readers I'll try and answer anyway. This situation is actually quite logical and straightforward once you get it but a common source of confusion for beginners.
So the simplest course of action is to remember that Ableton doesn't see the mirroring and adjust the output assignment accordingly. i.e. Ableton main outs 1-2 should go to MOTU line outs 1-2. Like the OP figured.
Alternatives include going in to the MOTU audio console and setting up MOTU main outs as a separate output pair in their own right or sending you main output signal to MOTU S/PDIF out. Looping the cable back to MOTU S/PDIF in and using you DAW output as an input to Cuemix.
That's right. That's how it works. In the default install options MOTU main out 1-2 are set to mirror MOTU line outs 1-2. They should be the exact same output. So logically the controls and slightly less logically the channel metering are disabled on MOTU Main outs 1-2.1. How can I route Ableton OUT 1/2 to MOTU Analog OUT 1/2?
See above. Use the controls and metering for MOTU line out 1-2 instead of MOTU main out 1-2.2. How can I change Output Volumes (or actually see signal movements) in CueMIX? No matter what I do (sound is heard), theres nothing happening in there? Do I need another software? I'm very used to RME's Total Mix so I'm a bit lost here.
