Hi guys this is my first post here,
I'm trying to get my Motu audio express to record audio into my daw I use both Cubase and Ableton. I can hear audio through my monitor speakers and headphones when I talk into the microphone. Its a rode NT-1 condenser mic.
I have enabled phantom power on the Motu and there is audio coming through cue mix(motu software on windows) from the microphone. The motu is set to be my primary recording device on windows (using windows xp).
I'm sure that all my firmware and drivers are up to date.
Hell i can even record audio on to windows using the "sound recorder" application(windows software) through the condenser mic.
Anybody out there had this problem and know how to fix it?
Thanks in advance,
Max
[SOLVED]Motu Audio Express Not Recording Into Daw
Re: Motu Audio Express Not Recording Into Daw
*SOLVED*
Here's how i did it: I reset the motu audio express by holding the "volume" and "phones" buttons simultaneously then an upside down "P" symbol appeared and after that it worked fine.
