After meticulous reconfiguring & editing, I have finally completed the Touch OSC Cuemix Template for the iPhone and I pod Touch.
The template contains all controls for inputs, outputs, mixes, channel control, the compressors & Limiters, eq, & reverb. The only buttons I had to remove (because of space) are the talk back and listen buttons. The. Monitor select buttons are. Still intact.
I took on this project basically for myself, I don't understand why OSC templates for the iPhone doe not exist. I could not find any complete mappings from anyone online so I underwent the process. I. Have used, tested, altered, edited, & then reconfigured these, so hopefully they are of some use for anyone else trying to use these. Feedback, ideas, etc. Are totally welcome. Comment below if you have anyprob.'s w/ the link.
iPhone 6/ 6s
https://drive.google.com/open?id=0B54dM ... HdfbzZJSTQ
iphone4/iPod 4https://drive.google.com/file/d/0B54dMJ ... sp=sharing
Free iPhone 6s TouchOSC Template DL for MK3 CUEMIX *UPDATE
Re: New iPhone OSC Template DL for CueMix (Dr. M )2014
I've sent you an access request as per your link. Thanks for posting. Looking forward to trying this out. Welcome to the forum!
Open access to downloading this template should now be allowed to everyone clicking the link.
Comment if there's still more troubles, I'm still setting up the account.
I would be all for this template being added to the OSC Templates 1.0 DL Pack, as long as I am credited.
So the people don't have to dig around for it, it's up to MOTU.
I presume the template operates correctly, with all the Downloads and no comments. I do appreciate feedback, if you like it, or have any feedback, let me know.
Still available for free download.
Tested the link, download, and upload to iPhone 6s, connection and visual feedback.
It's all good to go.
Here's some pictures of the layouts
Pg 1 MIX: Levels, mutes, pans, and mix select
Pg 2 - INPUTS: Input Trim, compression & eq, sends & bus select with main mix controls
Pg 3 - OUTPUTS: Trim levels. Compressor & eq control, monitor select
Pg 4 - DYNAMICS: Compressor & Leveler full control with channel select, auxiliary controls
Pg 5 - EQ: Full EQ control with channel select
Pg 6 - REVERB: Full Reverb Control
Re: Free iPhone 6s TouchOSC Template DL for MK3 CUEMIX *UPDA
Now updated for iPhone 6 & 6s!!
Both links for the iPhone 4 & 6 are linked in the top post.
