Traveler driver always bsod
torrentg
Post by torrentg »
I'm a very skilled bsod analysts and my machine is in perfect order physically and driver-wise. Well, that is besides always the MOTU driver. It is the one and only driver that crashes my machine because it seems to be poorly written. I am referring to this crash dump:
Code: Select all
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [D:\Windows\Minidump\060210-22718-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\SymCache*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.20655.x86fre.win7_ldr.100226-1909
Machine Name:
Kernel base = 0x83852000 PsLoadedModuleList = 0x83991570
Debug session time: Wed Jun  2 01:46:57.464 2010 (UTC - 4:00)
System Uptime: 0 days 8:47:58.121
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image motufwa.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for motufwa.sys
*** ERROR: Module load completed but symbols could not be loaded for motufwa.sys
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 100000D1, {b315802c, 2, 1, 92510315}
Probably caused by : motufwa.sys ( motufwa+30315 )
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: b315802c, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, value 0 = read operation, 1 = write operation
Arg4: 92510315, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 839b1700
Unable to read MiSystemVaType memory at 839910c0
 b315802c
CURRENT_IRQL:  2
FAULTING_IP:
motufwa+30315
92510315 8974102c        mov     dword ptr [eax+edx+2Ch],esi
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
LAST_CONTROL_TRANSFER:  from 838a672f to 92510315
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
9f197c98 838a672f 87cfa4e8 87cfa5a8 00000000 motufwa+0x30315
9f197d10 924f9d00 889359d8 00000000 9f197d50 nt!KeWaitForSingleObject+0x393
9f197d50 83a39d6e 889359cc a2813053 00000000 motufwa+0x19d00
9f197d90 838db0f9 924f9d60 889359cc 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
STACK_COMMAND:  kb
FOLLOWUP_IP:
motufwa+30315
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  motufwa+30315
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: motufwa
IMAGE_NAME:  motufwa.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4b9530b5
FAILURE_BUCKET_ID:  0xD1_motufwa+30315
0: kd> lmvm motufwa
start    end        module name
924e0000 92554000   motufwa  T (no symbols)
    Loaded symbol image file: motufwa.sys
    Image path: motufwa.sys
    Image name: motufwa.sys
    Timestamp:        Mon Mar 08 12:15:33 2010 (4B9530B5)
    CheckSum:         0007B06B
    ImageSize:        00074000
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
0: kd> lmtn
80bb8000 80bc0000   kdcom    kdcom.dll    Mon Jul 13 21:08:58 2009 (4A5BDAAA)
8381b000 83852000   hal      hal.dll      Tue Jul 21 02:32:34 2009 (4A656102)
83852000 83c52000   nt       ntkrnlmp.exe Sat Feb 27 02:34:58 2010 (4B88CB22)
84400000 84425000   viamraid viamraid.sys Mon Feb 22 03:35:44 2010 (4B8241E0)
84437000 844af000   mcupdate mcupdate.dll Mon Jul 13 21:06:41 2009 (4A5BDA21)
844af000 844c0000   PSHED    PSHED.dll    Mon Jul 13 21:09:36 2009 (4A5BDAD0)
844c0000 844c8000   BOOTVID  BOOTVID.dll  Mon Jul 13 21:04:34 2009 (4A5BD9A2)
844c8000 8450a000   CLFS     CLFS.SYS     Mon Jul 13 19:11:10 2009 (4A5BBF0E)
8450a000 845b5000   CI       CI.dll       Mon Jul 13 21:09:28 2009 (4A5BDAC8)
845b5000 84626000   Wdf01000 Wdf01000.sys Mon Jul 13 19:11:36 2009 (4A5BBF28)
84626000 84634000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
84634000 8467c000   ACPI     ACPI.sys     Mon Jul 13 19:11:11 2009 (4A5BBF0F)
8467c000 84685000   WMILIB   WMILIB.SYS   Mon Jul 13 19:11:22 2009 (4A5BBF1A)
84685000 8468d000   msisadrv msisadrv.sys Mon Jul 13 19:11:09 2009 (4A5BBF0D)
8468d000 846b7000   pci      pci.sys      Mon Jul 13 19:11:16 2009 (4A5BBF14)
846b7000 846c2000   vdrvroot vdrvroot.sys Mon Jul 13 19:46:19 2009 (4A5BC74B)
846c2000 846d3000   partmgr  partmgr.sys  Mon Jul 13 19:11:35 2009 (4A5BBF27)
846d3000 846e3000   volmgr   volmgr.sys   Mon Jul 13 19:11:25 2009 (4A5BBF1D)
846e3000 8472e000   volmgrx  volmgrx.sys  Mon Jul 13 19:11:41 2009 (4A5BBF2D)
8472e000 84736000   viaide   viaide.sys   Mon Jul 13 19:11:20 2009 (4A5BBF18)
84736000 84744000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:11:15 2009 (4A5BBF13)
84744000 8474c000   videX32  videX32.sys  Thu Aug 13 06:32:01 2009 (4A83EBA1)
8474c000 84762000   mountmgr mountmgr.sys Mon Jul 13 19:11:27 2009 (4A5BBF1F)
84762000 8476b000   atapi    atapi.sys    Mon Jul 13 19:11:15 2009 (4A5BBF13)
8476b000 8478e000   ataport  ataport.SYS  Mon Jul 13 19:11:18 2009 (4A5BBF16)
8478e000 847c3000   Si3124r5 Si3124r5.sys Wed Sep 20 13:06:45 2006 (45117525)
847c3000 847e9000   SCSIPORT SCSIPORT.SYS Mon Jul 13 19:45:55 2009 (4A5BC733)
847e9000 84800000   SI3124   SI3124.sys   Fri Mar 21 15:33:18 2008 (47E40D7E)
8a000000 8a030000   atikmpag atikmpag.sys Tue May 04 21:23:00 2010 (4BE0C874)
8a03a000 8a081000   storport storport.sys Mon Jul 13 19:45:58 2009 (4A5BC736)
8a081000 8a08a000   amdxata  amdxata.sys  Tue May 19 13:57:35 2009 (4A12F30F)
8a08a000 8a0be000   fltmgr   fltmgr.sys   Mon Jul 13 19:11:13 2009 (4A5BBF11)
8a0be000 8a0cf000   fileinfo fileinfo.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
8a0cf000 8a0d2100   SiWinAcc SiWinAcc.sys Thu Jun 14 20:02:27 2007 (4671D713)
8a0d3000 8a202000   Ntfs     Ntfs.sys     Mon Jul 13 19:12:05 2009 (4A5BBF45)
8a202000 8a22d000   msrpc    msrpc.sys    Mon Jul 13 19:11:59 2009 (4A5BBF3F)
8a22d000 8a240000   ksecdd   ksecdd.sys   Mon Jul 13 19:11:56 2009 (4A5BBF3C)
8a240000 8a29d000   cng      cng.sys      Mon Jul 13 19:32:55 2009 (4A5BC427)
8a29d000 8a2ab000   pcw      pcw.sys      Mon Jul 13 19:11:10 2009 (4A5BBF0E)
8a2ab000 8a2b4000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:11:14 2009 (4A5BBF12)
8a2b4000 8a36b000   ndis     ndis.sys     Fri Jul 24 01:52:34 2009 (4A694C22)
8a36b000 8a3a9000   NETIO    NETIO.SYS    Mon Jul 13 19:12:35 2009 (4A5BBF63)
8a3a9000 8a3ce000   ksecpkg  ksecpkg.sys  Thu Dec 10 23:04:22 2009 (4B21C4C6)
8a3ce000 8a3e5000   tdx      tdx.sys      Mon Jul 13 19:12:10 2009 (4A5BBF4A)
8a3e5000 8a3f0000   TDI      TDI.SYS      Mon Jul 13 19:12:12 2009 (4A5BBF4C)
8a400000 8a40b000   Msfs     Msfs.SYS     Mon Jul 13 19:11:26 2009 (4A5BBF1E)
8a40b000 8a419000   Npfs     Npfs.SYS     Mon Jul 13 19:11:31 2009 (4A5BBF23)
8a41a000 8a563000   tcpip    tcpip.sys    Fri Jul 24 01:53:23 2009 (4A694C53)
8a563000 8a594000   fwpkclnt fwpkclnt.sys Fri Jul 24 01:52:20 2009 (4A694C14)
8a594000 8a59c380   vmstorfl vmstorfl.sys Mon Jul 13 19:28:44 2009 (4A5BC32C)
8a59d000 8a5dc000   volsnap  volsnap.sys  Mon Jul 13 19:11:34 2009 (4A5BBF26)
8a5dc000 8a5ed000   uagp35   uagp35.sys   Mon Jul 13 19:25:40 2009 (4A5BC274)
8a5ed000 8a5f5000   spldr    spldr.sys    Mon May 11 12:13:47 2009 (4A084EBB)
8a5f5000 8a5f6480   speedfan speedfan.sys Sun Sep 24 09:28:47 2006 (4516880F)
8a5f7000 8a624000   rdyboost rdyboost.sys Mon Jul 13 19:22:02 2009 (4A5BC19A)
8a624000 8a62c000   SiRemFil SiRemFil.sys Wed Jun 20 16:06:09 2007 (467988B1)
8a62c000 8a63c000   mup      mup.sys      Mon Jul 13 19:14:14 2009 (4A5BBFC6)
8a63c000 8a644000   hwpolicy hwpolicy.sys Mon Jul 13 19:11:01 2009 (4A5BBF05)
8a644000 8a644680   giveio   giveio.sys   Wed Apr 03 22:33:25 1996 (316334F5)
8a645000 8a677000   fvevol   fvevol.sys   Fri Sep 25 22:24:21 2009 (4ABD7B55)
8a677000 8a68f080   firedrv  firedrv.sys  Mon May 04 08:52:35 2009 (49FEE513)
8a690000 8a6a1000   disk     disk.sys     Mon Jul 13 19:11:28 2009 (4A5BBF20)
8a6a1000 8a6c6000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:11:20 2009 (4A5BBF18)
8a6c6000 8a715000   srv2     srv2.sys     Mon Jul 13 19:14:52 2009 (4A5BBFEC)
8a723000 8a742000   cdrom    cdrom.sys    Tue Jul 21 02:32:53 2009 (4A656115)
8a742000 8a790000   klif     klif.sys     Tue Sep 22 06:31:42 2009 (4AB8A78E)
8a790000 8a797000   Null     Null.SYS     Mon Jul 13 19:11:12 2009 (4A5BBF10)
8a797000 8a79e000   Beep     Beep.SYS     Mon Jul 13 19:45:00 2009 (4A5BC6FC)
8a79e000 8a7a8000   dwvkbd   dwvkbd.sys   Wed Apr 11 17:23:28 2007 (461D51D0)
8a7a8000 8a7b4000   vga      vga.sys      Mon Jul 13 19:25:50 2009 (4A5BC27E)
8a7b4000 8a7d5000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:25:49 2009 (4A5BC27D)
8a7d5000 8a7e2000   watchdog watchdog.sys Mon Jul 13 19:24:10 2009 (4A5BC21A)
8a7e2000 8a7ea000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:01:40 2009 (4A5BCAE4)
8a7ea000 8a7f2000   rdpencdd rdpencdd.sys Mon Jul 13 20:01:39 2009 (4A5BCAE3)
8a7f2000 8a7fa000   rdprefmp rdprefmp.sys Mon Jul 13 20:01:41 2009 (4A5BCAE5)
90c0f000 9112f000   kl1      kl1.sys      Fri Sep 25 09:59:00 2009 (4ABCCCA4)
9112f000 91189000   afd      afd.sys      Mon Jul 13 19:12:34 2009 (4A5BBF62)
91189000 911bb000   netbt    netbt.sys    Mon Jul 13 19:12:18 2009 (4A5BBF52)
911bb000 91245000   vsdatant vsdatant.sys Fri Mar 19 02:42:51 2010 (4BA31CEB)
91245000 9124c000   wfplwf   wfplwf.sys   Mon Jul 13 19:53:51 2009 (4A5BC90F)
9124c000 9126b000   pacer    pacer.sys    Mon Jul 13 19:53:58 2009 (4A5BC916)
9126b000 9127c000   vwififlt vwififlt.sys Mon Jul 13 19:52:03 2009 (4A5BC8A3)
9127c000 9128a000   netbios  netbios.sys  Mon Jul 13 19:53:54 2009 (4A5BC912)
9128a000 912a1000   rassstp  rassstp.sys  Mon Jul 13 19:54:57 2009 (4A5BC951)
912a4000 912b7000   wanarp   wanarp.sys   Mon Jul 13 19:55:02 2009 (4A5BC956)
912b7000 912c7000   termdd   termdd.sys   Mon Jul 13 20:01:35 2009 (4A5BCADF)
912c7000 912d4a60   SCDEmu   SCDEmu.SYS   Mon Apr 12 04:44:34 2010 (4BC2DD72)
912d5000 91316000   rdbss    rdbss.sys    Mon Jul 13 19:14:26 2009 (4A5BBFD2)
91316000 91320000   nsiproxy nsiproxy.sys Mon Jul 13 19:12:08 2009 (4A5BBF48)
91320000 9132a000   mssmbios mssmbios.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
9132a000 91336000   discache discache.sys Mon Jul 13 19:24:04 2009 (4A5BC214)
91336000 9139a000   csc      csc.sys      Mon Jul 13 19:15:08 2009 (4A5BBFFC)
9139a000 913b2000   dfsc     dfsc.sys     Mon Jul 13 19:14:16 2009 (4A5BBFC8)
913b2000 913c0000   blbdrive blbdrive.sys Mon Jul 13 19:23:04 2009 (4A5BC1D8)
913c0000 913c3e80   atitray  atitray.sys  Thu Apr 22 00:14:26 2010 (4BCFCD22)
913c4000 913d6000   intelppm intelppm.sys Mon Jul 13 19:11:03 2009 (4A5BBF07)
913d6000 913ed000   raspptp  raspptp.sys  Mon Jul 13 19:54:47 2009 (4A5BC947)
913ed000 913fa000   mouclass mouclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
91c00000 91c22000   ndiswan  ndiswan.sys  Mon Jul 13 19:54:34 2009 (4A5BC93A)
91c22000 91c2c000   rdpbus   rdpbus.sys   Mon Jul 13 20:02:40 2009 (4A5BCB20)
91c2c000 91c2d380   swenum   swenum.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
91c32000 921cc000   atikmdag atikmdag.sys Tue May 04 21:33:36 2010 (4BE0CAF0)
921cc000 92283000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 20:48:33 2009 (4AC54DE1)
92283000 922bc000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:25:25 2009 (4A5BC265)
922bc000 922db000   HDAudBus HDAudBus.sys Mon Jul 13 19:50:55 2009 (4A5BC85F)
922db000 922ea000   Rtnicxp  Rtnicxp.sys  Thu Jul 23 10:02:57 2009 (4A686D91)
922ea000 922f9400   ohci1394 ohci1394.sys Mon Jul 13 19:51:29 2009 (4A5BC881)
922fa000 9230e000   1394BUS  1394BUS.SYS  Mon Jul 13 19:51:21 2009 (4A5BC879)
9230e000 92319000   usbuhci  usbuhci.sys  Sat Jun 13 04:01:47 2009 (4A335CEB)
92319000 92364000   USBPORT  USBPORT.SYS  Sat Jun 13 04:01:50 2009 (4A335CEE)
92364000 92373000   usbehci  usbehci.sys  Sat Jun 13 04:01:51 2009 (4A335CEF)
92373000 9238b000   i8042prt i8042prt.sys Mon Jul 13 19:11:23 2009 (4A5BBF1B)
9238b000 9238e500   L8042Kbd L8042Kbd.sys Tue Nov 10 06:47:03 2009 (4AF952B7)
9238f000 9239c000   kbdclass kbdclass.sys Mon Jul 13 19:11:15 2009 (4A5BBF13)
9239c000 923a9000   CompositeBus CompositeBus.sys Mon Jul 13 19:45:26 2009 (4A5BC716)
923a9000 923a9e80   DamewareMini DamewareMini.sys Sun Mar 16 14:41:51 2008 (47DD69EF)
923aa000 923b3000   MotuBus  MotuBus.sys  Mon Mar 08 12:28:23 2010 (4B9533B7)
923b3000 923c5000   AgileVpn AgileVpn.sys Mon Jul 13 19:55:00 2009 (4A5BC954)
923c5000 923dd000   rasl2tp  rasl2tp.sys  Mon Jul 13 19:54:33 2009 (4A5BC939)
923dd000 923e8000   ndistapi ndistapi.sys Mon Jul 13 19:54:24 2009 (4A5BC930)
923e8000 92400000   raspppoe raspppoe.sys Mon Jul 13 19:54:53 2009 (4A5BC94D)
92436000 9246a000   ks       ks.sys       Mon Jul 13 19:45:13 2009 (4A5BC709)
9246a000 9246df00   WmBEnum  WmBEnum.sys  Fri Sep 11 15:39:56 2009 (4AAAA78C)
9246e000 9247c800   WmXlCore WmXlCore.sys Fri Sep 11 15:39:53 2009 (4AAAA789)
9247d000 9248b000   umbus    umbus.sys    Tue Jul 21 03:14:01 2009 (4A656AB9)
9248b000 924cf000   usbhub   usbhub.sys   Tue Jul 21 03:14:29 2009 (4A656AD5)
924cf000 924e0000   NDProxy  NDProxy.SYS  Mon Jul 13 19:54:27 2009 (4A5BC933)
924e0000 92554000   motufwa  motufwa.sys  Mon Mar 08 12:15:33 2010 (4B9530B5)
92554000 92555700   USBD     USBD.SYS     Sat Jun 13 04:01:41 2009 (4A335CE5)
92556000 9256c000   cdfs     cdfs.sys     Mon Jul 13 19:11:14 2009 (4A5BBF12)
9256c000 92577000   hidusb   hidusb.sys   Mon Jul 13 19:51:04 2009 (4A5BC868)
92577000 9258a000   HIDCLASS HIDCLASS.SYS Mon Jul 13 19:51:01 2009 (4A5BC865)
9258a000 92590480   HIDPARSE HIDPARSE.SYS Mon Jul 13 19:50:59 2009 (4A5BC863)
92591000 9259d000   kbdhid   kbdhid.sys   Mon Jul 13 19:45:09 2009 (4A5BC705)
9259d000 925a2580   LUsbFilt LUsbFilt.Sys Tue Nov 10 06:45:43 2009 (4AF95267)
925a3000 925ad000   x10ufx2  x10ufx2.sys  Thu Nov 30 18:18:56 2006 (456F66E0)
925ad000 925b7000   Dxapi    Dxapi.sys    Mon Jul 13 19:25:25 2009 (4A5BC265)
925b7000 925ce000   USBSTOR  USBSTOR.SYS  Mon Jul 13 19:51:19 2009 (4A5BC877)
925ce000 925d8000   mfwamidi mfwamidi.sys Mon Mar 08 12:16:48 2010 (4B953100)
925d8000 92607000   portcls  portcls.sys  Mon Jul 13 19:51:00 2009 (4A5BC864)
92607000 92620000   drmk     drmk.sys     Mon Jul 13 20:36:05 2009 (4A5BD2F5)
92620000 92633000   mfwawave mfwawave.sys Mon Mar 08 12:15:58 2010 (4B9530CE)
92633000 9263a280   LHidFilt LHidFilt.Sys Tue Nov 10 06:45:35 2009 (4AF9525F)
9263b000 92646000   mouhid   mouhid.sys   Mon Jul 13 19:45:08 2009 (4A5BC704)
92646000 9264d800   LMouFilt LMouFilt.Sys Tue Nov 10 06:45:40 2009 (4AF95264)
9264e000 92655100   WmFilter WmFilter.sys Fri Sep 11 15:39:56 2009 (4AAAA78C)
92656000 92663000   crashdmp crashdmp.sys Mon Jul 13 19:45:50 2009 (4A5BC72E)
92663000 9266d000   dump_scsiport dump_scsiport.sys Mon Jul 13 19:45:49 2009 (4A5BC72D)
9266d000 926a2000   dump_Si3124r5 dump_Si3124r5.sys Wed Sep 20 13:06:45 2006 (45117525)
926a2000 926b3000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:12:47 2009 (4A5BBF6F)
926b3000 926be000   monitor  monitor.sys  Mon Jul 13 19:25:58 2009 (4A5BC286)
926be000 926d9000   luafv    luafv.sys    Mon Jul 13 19:15:44 2009 (4A5BC020)
926d9000 926f3000   WudfPf   WudfPf.sys   Mon Jul 13 19:50:13 2009 (4A5BC835)
926f3000 9270af80   nbf      nbf.sys      Fri Aug 17 16:53:59 2001 (3B7D8467)
9270b000 9271b000   lltdio   lltdio.sys   Mon Jul 13 19:53:18 2009 (4A5BC8EE)
9271b000 9272e000   rspndr   rspndr.sys   Mon Jul 13 19:53:20 2009 (4A5BC8F0)
9272e000 92736000   ISWKL    ISWKL.sys    Tue Mar 16 04:14:21 2010 (4B9F3DDD)
92736000 92757000   srvnet   srvnet.sys   Tue Dec 08 03:05:06 2009 (4B1E08B2)
92757000 92770000   bowser   bowser.sys   Mon Jul 13 19:14:21 2009 (4A5BBFCD)
92770000 92793000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:32:02 2010 (4B88CA72)
92793000 927ce000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:32:21 2010 (4B88CA85)
927ce000 927e9000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:32:11 2010 (4B88CA7B)
940a0000 942ea000   win32k   win32k.sys   Sat Aug 29 00:27:02 2009 (4A98AE16)
94300000 94309000   TSDDD    TSDDD.dll    Mon Jul 13 20:01:40 2009 (4A5BCAE4)
94330000 9437d000   ATMFD    ATMFD.DLL    Thu Jul 30 00:44:10 2009 (4A71251A)
94380000 9439e000   cdd      cdd.dll      Mon Jul 13 21:04:18 2009 (4A5BD992)
9fc19000 9fc6a000   srv      srv.sys      Tue Dec 08 03:05:37 2009 (4B1E08D1)
9fc82000 9fc85180   cpuz132_x32 cpuz132_x32.sys Thu Mar 26 19:16:27 2009 (49CC0CCB)
9fc86000 9fc8f000   cpuz133_x32 cpuz133_x32.sys Tue Mar 30 17:38:01 2010 (4BB26F39)
9fc8f000 9fc99000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
9fc99000 9fca6000   tcpipreg tcpipreg.sys Mon Jul 13 19:54:14 2009 (4A5BC926)
9fca6000 9fcd2000   000      000.fcl      Fri Sep 26 09:11:12 2008 (48DCDF70)
Unloaded modules:
9fd44000 9fdae000   spsys.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
    ImageSize:  0006A000
9fd3c000 9fd44000   mbamswissarm
    Checksum:  00000000
    ImageSize:  00008000
9fcd2000 9fd3c000   spsys.sys
    Checksum:  00000000
    ImageSize:  0006A000
9fc6a000 9fc82000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
8a6c6000 8a6d3000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
8a6d3000 8a6dd000   dump_scsipor
    Checksum:  00000000
    ImageSize:  0000A000
8a6dd000 8a712000   dump_Si3124r
    Checksum:  00000000
    ImageSize:  00035000
8a712000 8a723000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
9128a000 912a4000   serial.sys
    Checksum:  00000000
    ImageSize:  0001A000
This is not very difficult to repair in the driver, MOTU. Please get on this asap because I've been suffering this on machine for years now.
I kindly offer my services free of charge if you need an inside hand with beta testing anything that you come up with. I don't have the actual skills to fix this driver but I know your team does. Please let me work with you as a tester, if necessary.
Any thoughts, please?
torrentg
Re: Traveler driver always bsod
Post by torrentg »
Bumping because this is still a concern here. Very much hoping MOTU will finally alleviate this problem with a new driver soon. System uptime is impossible for longer than 3 or 4 days due to this error rearing its ugly head every so often.
Interested in any comments by other Traveler users or by MOTU staff.
Thanks.
Just be aware that this isn't an official MOTU forum so there's no way to predict if anyone from MOTU will even see this.
torrentg
Post by torrentg »
Hey James!
Great news. Chris, a representative of MOTU had contacted me about the issue. I sent him a crash dump showing the 0xD1 motufwa.sys.
He has replied that the issue has now been fixed and that there is a new driver available as of today on MOTU's site.
I just installed it and am listening to some music. Keeping fingers crossed that the issue has finally been solved after all these years.
I'm looking forward to a long system uptime for a change haha.
Chris, if you see this....thank you so much to your company and yourself. It's appreciated!
Wow! That's great news! Congratulations on a job well done to all parties involved!
FMiguelez
Post by FMiguelez »
Shooshie wrote:Wow! That's great news! Congratulations on a job well done to all parties involved!
+ 10000000000000000000
This just proves how a GOOD AND PROACTIVE ATTITUDE beats whining, bitching, ranting and bashing MOTU.
Any day!
8)
