I am using Digital Performer, I inserted a plug-in effect from the mixing board then tried to adjust it in the sequence window. I didn't like it so I deleted it but I am noticing these dotted lines and the drop-down says missing. Below is a picture of what I'm talking about squared in red:
How do I get rid of the dotted lines?
Removing Unwanted Effects
- SMS
Re: Removing Unwanted Effects
First off, it seems this post should be under general use, not user showcase.
To answer your question, those lines are automation data for the (now deleted) pug-ins. If you select one of those items from the menu you've highlighted, it becomes editable and eraseable in the sequence editor.
MOTU user since Performer™ 1.22 on 128k floppy
DP 11.23
MacBook Pro 14” 2023 M2 max 12 core
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
DP 11.23
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
Indeed. Moved.SMS wrote:First off, it seems this post should be under general use, not user showcase.
