Program goes through install routine normally until end, then get Windows error message, "A problem with the program caused the registry server to stop working. Windows will let you know if it finds a solution." (It doesn't find one.) I let the install program finish, then try to launch MSI and it gives the error message, "cannot find user interface DLL...reinstall..." Checking the windows drivers folder, I do not find any motuDLL. This is on a PC running Vista32, with latest iLok drivers installed. Tried reinstalling, uninstall and reinstall, run as administrator, no difference. Suggestions?
PS - The last attempt at installation which generated the error and warning list below was done with DEP turned off for the registry server. It made no difference from when DEP was on for all programs. Here are the relevant error and warning messages from Event Viewer:
Error:
Faulting application regsvr32.exe, version 6.0.6000.16386, time stamp 0x4549b3c7, faulting module kernel32.dll, version 6.0.6002.18005, time stamp 0x49e037dd, exception code 0xe06d7363, fault offset 0x0003fbae, process id 0x1448, application start time 0x01ca96e2771d1f61.
Error:
Windows Defender has encountered an error trying to load signatures and will attempt reverting back to a known-good set of signatures.
Signatures Attempted: Current
Error Code: 0x8050800c
Error description: An unexpected problem occurred. Install any available updates, and then try to start the program again. For information on installing updates, see Help and Support.
Signatures loading: Backup
Loading signature version: 1.71.2030.0
Loading engine version: 1.1.5302.0
Error:
The application-specific permission settings do not grant Local Launch permission for the COM Server application with CLSID
{C97FCC79-E628-407D-AE68-A06AD6D8B4D1}
to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC). This security permission can be modified using the Component Services administrative tool.
Warning:
Windows detected your registry file is still in use by other applications or services. The file will be unloaded now. The applications or services that hold your registry file may not function properly afterwards.
DETAIL -
15 user registry handles leaked from \Registry\User\S-1-5-21-3092488586-3237986233-1640636351-1000:
Process 1368 (\Device\HarddiskVolume1\WINDOWS\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3092488586-3237986233-1640636351-1000
Process 1368 (\Device\HarddiskVolume1\WINDOWS\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3092488586-3237986233-1640636351-1000\Software\Microsoft\SystemCertificates\SmartCardRoot
Process 1368 (\Device\HarddiskVolume1\WINDOWS\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3092488586-3237986233-1640636351-1000\Software\Policies\Microsoft\SystemCertificates
Process 1368 (\Device\HarddiskVolume1\WINDOWS\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3092488586-3237986233-1640636351-1000\Software\Microsoft\SystemCertificates\TrustedPeople
Process 1368 (\Device\HarddiskVolume1\WINDOWS\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3092488586-3237986233-1640636351-1000\Software\Microsoft\SystemCertificates\Root
Process 1368 (\Device\HarddiskVolume1\WINDOWS\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3092488586-3237986233-1640636351-1000\Software\Microsoft\SystemCertificates\My
Process 1368 (\Device\HarddiskVolume1\WINDOWS\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3092488586-3237986233-1640636351-1000\Software\Microsoft\SystemCertificates\CA
Process 1368 (\Device\HarddiskVolume1\WINDOWS\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3092488586-3237986233-1640636351-1000\Software\Microsoft\SystemCertificates\trust
Process 1368 (\Device\HarddiskVolume1\WINDOWS\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3092488586-3237986233-1640636351-1000\Software\Microsoft\SystemCertificates\Disallowed
Ver 1.1.3 won't install on Vista PC
Re: Ver 1.1.3 won't install on Vista PC
Man, what a headache. BUT, the problem is fixed. For anyone having the same problem here's what I did (a combination of suggestions from MOTU tech support and slogging through forum posts):
- remove Internet Explorer 8 (Vista automatically reverts to IE7)
- download the MSI Installer FROM THE MOTU WEBSITE . Don't use the one that came in the box. The one on the website is listed as Vista 32 bit Beta prerelease (but it's not), and version code is 1.1.3b2
- install the soundfile disk first
- insert the iLok dongle
- run the MSI installer program
- let it do a full install (don't click any other selections such as VST)
- click "add another VST location" as many times as it takes (like, 40x) to get the blue bar all the way across the popup box
It finishes installing without hanging up at "registry server stopped working"
