Plugin redraws are dead slow
Hi all,
This is an interesting problem I've had for several years now, but would like to tackle it once and for all:
Scenario 1: Any waves plug and an open video window
If I have a video window up while I have any Waves plug open and I move a knob or slider, the interface updates 1-2 times a second, as opposed to the usual truly interactive way. If I close the video window, the problem goes away.
Scenario 2: Newfangled Audio's Equivocate
I see the above mentioned slow knob redraws also with either once instance of Equivocate and open video window, or two instances of Equivocate (with or without an open video window). I believe this is a graphics problem, as if I put one Equivocate instance on top of the other and completely obscure one instances sliders, the problem goes away.
I've updated from OS 10.11.5 to '.6, tried the latest GeForce Driver, and ensured I had the latest Waves plugs...all to no avail. I've also spoken with the great MOTU Tech Support (and yes, they're great), and they've never come across this.
TIA for any light you can shed here,
Len
Len
2013 Trashcan, 12 core, 10.14.6, 64GB RAM,
http://www.uncannymusic.com
Re: Plugin redraws are dead slow
It does on the surface sound as if the video card can't keep up with that specific demand. Can't say for sure.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
It does, but my usage here isn't unique. Waves is widely used, along with a video window. All other graphics look great and snappy, so unless that particular combination uses some unique portion of the card's circuitry, I'm at a loss thus far.
- Gravity Jim
I have the same upgraded computer as you, and I can tell you, the original video card is Old And Busted. You need the New Hotness.
"My usage isn't unique" sounds as if you are trying to say that DP should be able to run video alongside plugins with no problems on a 10-year-old Mac with the original GPU that was widely reviled when it came out. I don't think that's the case.
Upgrade your video card to something with at least a gigabyte of onboard RAM. I had the same problem until I swapped out the original card for an ATI Radeon HD... I actually drove 3 displays (one of which was a Slate Raven) for about 6 months with this card and had no video stuttering.
Jim Bordner
Which card did you go to Jim?Gravity Jim wrote:I have the same upgraded computer as you, and I can tell you, the original video card is Old And Busted. You need the New Hotness.
Since I wanted to get 4k video resolution, I moved from ATI (AMD) 5770 to AMD RX460 4GB (Gigabyte), which is one of the big reasons I moved from Mountain Lion to Sierra (GPU support). Mac-compatible 5770s are readily available now, but many newer GPUs are running pricey due to cryptocurrency miners' demand.
Back to the OP's Inquiry:
The card that came stock with the 4,1 Mac Pro is a GT120. It has 512MB RAM. It is possible this is your issue, but I am not at all sure. I have used the GT120 to drive a 2560 x 1080 widescreen monitor without difficulty. My guess is a software issue, as other plug-ins would likely be demonstrating the same behavior if the problem stemmed from hardware limitations.
HC Markus
- Gravity Jim
HC, I went with an ATI Radeon HD 5870.
Jim Bordner
Thanks Jim.Gravity Jim wrote:HC, I went with an ATI Radeon HD 5870.
Thanks all, especially Jim for weighing in here.
Yea, I've been looking at upgrading the video card. But...I'm skeptical I'm hitting its limitations as badly as you're saying, as everything else is cruising along just fine. Plenty of VI's and plugs are open...along with video...and nary a hiccup except for this particular situation.
Meh...should have taken up the flute.
Len
Len
I can only recall way back with the last gen G5, it was only a couple of years before the video card couldn't keep up with plug graphics, even though the computer had tons of headroom in activity monitor.
Doug Williams
Tape Op issue 73
DP 11.31
Tape Op issue 73
DP 11.31
OK...sounds like I should upgrade my card. Jim, I see there's a fan on yours, I believe. Is it quiet? I have the computer fairly close to me, and it's already making more noise than I care for, especially since bringing the processor tray up to 3.46 Ghz and 12 processors. Yea, cutting edge. For 2010.
I used to have this issue if certain plug GUIs were open. RX 3 Advanced was the worst as I recall. I had to have it open only, set it then close it for the DP graphics and other plug windows to run at anything near a decent speed.
I just got into the habit of closing plugin windows that weren’t necessary once I made the settings and haven’t had a problem since.
The 5770 in my iMac is the same as in most older Mac Pros but cannot be swapped.
Switching to SSDs only sped up the graphics on my 2010 iMac also. It wasn’t hard to figure out why but that was not expected.
The AMD 460 I am running makes no fan noise unless it is pushed... the fans idle at zero RPM. The 560 has replaced the 460; I think you need to be running Sierra to use either.
The GT120 is nice and quiet. The 5770 somewhat noisier. I still think it is unlikely that you GPU is the issue, but I have, on at least one occasion already this year, been wrong about something.
I have an extra mac version 5770 sitting in a box if you'd like to try it out. PM me if interested.
Thanks, Mike and Marcus, especially for the offer of trying out the card. I am wondering something additionally: Should I expect a graphics card to narrow the latency of video playback, or is this a function of internal bussing and processor decompression, do ya think? If the card's just acting as a frame buffer, I couldn't expect better movie performance, but like you said, I've been wrong about at least one thing. Probably at least since I woke up today.
Len
Len
I wouldn't expect it to*. Video editing would likely be impacted. For example, reports indicate Final Cut is optimized for AMD GPUs.dreamuse wrote: Should I expect a graphics card to narrow the latency of video playback?
Len
*this could be my second, possibly third error this year.
Well, a guy can hope. It'd be great to see everything get snappier, but alas, we're talking 9 year old bus speeds, etc...
