bounce to disk not working when aux busses involved
jglamar
Post by jglamar »
I can bounce to disk just fine under normal circumstances (running DP 9.51 on brand new iMac running 10.13.2).
But if I want to submix 2 channels to bus 1-2 and submix channels 3-4 to bus 3-4, and mix those 2 busses to the master bus, and try to bounce with the mast output selected, I get blank/empty/silent files.
This has been happening since upgrading to 9 about two months ago.
My only solution at this time is a realtime bounce to a new stereo channel in the sequence.
Any fixes?
FMiguelez
Re: bounce to disk not working when aux busses involved
Post by FMiguelez »
It works fine here.
Sounds to me like a problem in the setting of the BTD dialog box. Your tracks must be play-enabled and their ultimate out must coincide with the master's.
jglamar
Post by jglamar »
FMiguelez wrote: Your tracks must be play-enabled and their ultimate out must coincide with the master's.
The BTD box is configured correctly. I mentioned in the original post that bounces work fine unless aux tracks are involved.
For instance, if I configure tracks 1-2 ti feed bus 1-2, and add a stereo channel with input bus 1-2, output main 1-2, a bounce of the output of Main 1-2 will yield a silent file. All tracks play enabled, and the channel w/input from bus1-2 is in input mode.
I tested lots of permutations of this to no avail.
EMRR
Post by EMRR »
......aaaaaaaahhhhhhh.....feel like I've experienced this but I don't have any clear memory. I think I discovered a 3rd party plug on the aux that didn't function in BTD, only real time, but I can't swear to that.
I did notice recently you can’t assign outputs to ‘none’ and get sound through an aux send. That foils options I'd like for dual mid side and ambisonic mixing.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
