First off, it's NOT a big deal, however... when the transport is running with a movie playing (hi=res MP4 from the client - silent) and even if there are no tracks yet, setting the start or end time of the transport (whether clicking in the transport window or using a key command) causes the film to pause for about 1/3 to 1/2 second and then immediately regains sync. I'm not seeing the same hiccup when I insert a marker (with a key command). It seems to be limited to setting the transport. I don't recall that happening in earlier versions.
It's more of a visual distraction than a bug (per se) when setting the start or end time, which admittedly one generally doesn't do that often with the transport running. I sometimes SAVE with the transport running. No apparent hiccup there either. I know, I'm a bad boy, but I've saved with the transport running for years and never had an issue.
Anyway, other than that, 9.5 is running strong on my machine. I scored a short (15) silent film today and all seems to be working just fine.
Thanks MOTU!
Looking forward to DP 10...
Little hiccup in DP 9.5 setting start and end times
Re: Little hiccup in DP 9.5 setting start and end times
OMG.MIDI Life Crisis wrote:Looking forward to DP 10...
