In DP 9.13, I can understand the metering change from older versions to post fader. (although, there could probably still be an option to view pre fader levels as well.)
However, what makes absolutely no sense whatsoever, is now having the metering on a stereo track not reflect the change in the pan(balance) knob. Currently, it displays left and right levels of whatever is entering the channel, without any regard to the pan knob. Turn the balance knob hard left or right, effectively removing one side, and the meters will still show both sides unchanged.
This has got to be a bug, right?
Carlos
DP9.13
Mac Pro Dual Quad Core 2.8Ghz
OS 10.10.5
Mixing board metering bug?
