32 bit Float question for Magic Dave
Re: 32 bit Float question for Magic Dave
Well, all I can say at this point is that as an experiment in recording digital audio, I wish I had not done it. 32bfp serves a very real purpose in mixing. As an audio file format, it serves no purpose whatsoever for normal recording. It does not improve the perceptible quality of the audio. Any extension of the dynamic range is way beyond the useful range of music, anyway — and I'm talking about jet-plane exhaust to bug footsteps in the same room. There is no musical advantage to 32bfp.
My thinking was that it might facilitate ease of mixing with so much headroom that essentially I would never have to worry about digital clipping, and I could put off all dithering until the final 2-track. Those ideas were poorly thought-out, hastily decided upon, and without merit once you start doing the math and studying what goes into bit resolution. I think that 24 bits/48K is pretty much audiophile quality, and all we need in recording small studio projects. If we start recording rocket launches, then let's talk.
Until then, my conclusion is that 32bfp as an audio file format is not really a viable tool for the studio under most circumstances. I'm glad it's there; there may be a use for it. I just don't know what it is. 24 bits is all we would ever need, and even that is probably overkill for most digital audio applications. Then why do we need 32bfp at all? As a mixing domain. Because when mixing and processing 24 bit audio, we must be able to do that from within a more capacious format, or we will quickly run out of room. 32bfp is essentially 24 bits plus an 8 bit mantissa, so that it focuses 24 bits of resolution where it is needed at any given moment. My understanding is that this reduces rounding errors.
Rather than being easier to mix, 32bfp audio file format seems harder. Levels clip easily, and when they do, you hear it, contrary to my original rationale. Also, when working with amplifying and synthesizing bass harmonics, I'm picking up a LOT of noise from the floor. Actually, it's more like stuff outside the studio. Our guitar tracks are not recorded with the same shielding as the vocals, and if there was a bulldozer outside, you might pick up some rumble. Every day there seems to be a bulldozer or some other heavy machinery working on all these tear-downs and new houses. It had not been a problem until this 32bfp project. So, I'm using Waves' Z-Noise to remove it.
That's it. In a nutshell: 32bfp as an audio file format means more careful mixing and levels, more low-level audio noise (but lower digital noise floor). That has been my experience with this project. I'm not sure I can explain it, and I won't try. You'd be better off consulting people who think about this every day and who know the math without having to work through it each time. I'm just stating the differences I've noticed in this project, vs. my normal way of working. My other problems appear to have been unrelated to using the 32bfp audio file format, and appear to be fixed since installing the latest build of DP 9.13.
terrybritton wrote:Long and short of it - 32-bit float is handy for archiving to hand off for a mix and for internal processing, 24-bit is great for recording as it is within the range that most plugins can understand, and 16-bit with slightly compressed audio is ideal for listening environments with higher environmental noise floors than the 16-bit digital "noise" floor is (-96db on the meters).
Like, most of the planet!
Perfectly stated. 100% true. And I wish I'd thought of archiving as a use for 32bfp file format, which makes sense. Especially for stems. As your primary audio format, I do not recommend it.
Shoosh
- terrybritton
- Primary DAW OS: Windows
This is the point I was making in my last post - Magic Dave had gotten me on the wrong track with talking about crazy-high dynamic range from the 32-bit float... no, that is 32-bit integer there. The floating point version is, as you point out, 24-bit (thus that bit depth's dynamic range) plus a mantissa to reduce rounding errors.Shooshie wrote:32bfp is essentially 24 bits plus an 8 bit mantissa, so that it focuses 24 bits of resolution where it is needed at any given moment. My understanding is that this reduces rounding errors.
Something in the file format might be quite different - perhaps it is saved as 32-bit integer format to be re-absorbed interpreting the extra 8 bits as the mantissa upon loading? Dunno... but would like to!
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
If you are bouncing stems or mixes, 32f is a good idea because of the lack of gain penalty should you change the master later, no dither that can land in an audible range later.
I think Dave addressed the question of when dither is and is not applied in DP last year, can't recall the specifics right now. It may still be an open question.
Since I usually mix analog, the 24 bit soundbites headed to a DA converter get a post fader 24 bit dither plug, and I am of the OPINION it sounds a bit smoother and better that way. That re-dithers for any processing or level changes.
I've been in the habit of mixing even analog back in at 32f, even though individual tracks come in at 24. 32f capture may not be doing anything for me like this, even though it would if it were a bounce.
Using the 16A interface, the code stream appears to be 24 bit, with Audio/MIDI describing 32bit float paths for in and out, so if you send a 32 bit word from DP the 16A receives it. The output trims are digital and use the DAC's internal trim. Does it apply dither of it's own? The DAC chip is described as 32 bit input and filter architecture, selectable roll-off freq, soft mute and volume control. The rolloff and volume choice imply dither, but it's not specified that I can find. It's possible I'm double-dithering.
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
Important to note that we're comparing 24-bit *fixed-point* with 32-bit *floating point.* It's that last part - fixed-point vs floating-point - that makes all the difference. One way to think of things, though it's a bit simplified, would be that the range of 24-bit fixed-point lives right in the middle of the much broader 32-bit floating-point range. Floating point lets you adequately describe both much louder signals and much softer signals. So, while the comment below is correct for fixed point, floating point is different:terrybritton wrote:My understanding is that in any format, 0DB is still all ones or "full-on", and the resolution goes in the "quieter than full-on" direction, which is why 24-bit is better for reverb tails and piano string fades, and we have all that room to use -12db as our peak value. (The quieter the content is, the fewer bits it uses.)stubbsonic wrote:Just out of curiosity (and some ignorance thrown in for good measure)-- I'd like to understand the difference between RESOLUTION and GAIN where the bit format is concerned.
When DP is using a 32-float, does the factor of it being "float" mean that it is interpreting the 32 bits to have a higher resolution as opposed to having 1500 dB of gain?
To ask a different way, if I have 16 bit audio normalized and the same audio as 24 bit normalized, I expect it to look same on the meters, but the 24 bit file will just have more resolution. I don't know what has to happen behind the scenes with the DACs to make that so. When we have 32-float files, should we expect them to look different on the meters (and clip internally?)
So, yes, there is more resolution, especially for the quiet sections which, in 16-bit, become very low bit "words", while staying "longer words" with 24-bit even at the same low "volume" (all things being relative to "full-on"). 32-bit is 24-bit with room left for even more fine-tuning between levels with the mantissa/decimal fractions added. So, that being the case, higher resolution is what you are getting there, too.
Terry
Shoshie, as I read about your distortion issues, one thing that struck me was that they went away after you rebooted. That points to not enough RAM. There are ways to free up some RAM during the process like running sudo purge in Terminal but nothing clears it like a reboot. I know you also found a bad stick.
After Dave's post, I'm convinced of it.
That was my conclusion, too, no matter how much nonsense I read on Gearslutz when I tried to research the subject.There is no good reason to record at 32 bit float...
I don't know, Mike. I've got 40 GB RAM, all working and passed all the tests of Rember, the RAM tester. My files just aren't that big. Anywhere from 5 to 10 audio tracks, some automation on aux tracks, and a few compressors, limiters, and Altiverb.
I don't really know where things stand right now. Around the time that I upgraded to the latest build of DP, I had gotten my levels pretty well adjusted so that I wasn't getting any clipping. The newer build solved the intermittent problems, as far as I can tell. I haven't gone back and overloaded my busses to see if I'm still getting the distortion when that happens. Maybe it ALL was due to the previous DP build. I'll be able to test things more when I'm done with this album, in a few days I hope.
Shoosh
Shoosh
- Timeline
With the latest build of DP I have not had this issue but I use the precision limiter from UA as a final PL. I wonder though, UA automatically sets a -.1 into the ceiling when inserting into a master or channel fader. Could be they would also have a comment or two about 32BF. I have seen the problem pop up curiously in the past BTW and I think I remember that it was intermittent. Thanks Dave for that input BTW.
Cheers,
GB
Cheers,
GB
I found this lengthy discussion reminded me of a
recent exchange I had with someone who
sent me some stems to cut a new vocal over. The
exchange went something like this (condensed
here, of course):
YOUNG SONGWRITER: Ok I sent the stems. I
record at 32 bits. Can you please record the vocals
at 32 bits?
ME: 32 bits? That is your audio format?
The stems you sent are 24-bit 44.1khz WAV.
YS: Yes I record at 32 bits.
ME: Wait a minute. How old is your DAW?
YS: Way old, like 6 years.
ME: I think you mean your DAW is a 32-bit
application.
YS: Let me check...yes, it is.
here, of course):
at 32 bits?
application.
http://www.davepolich.com
Hilarious!!
Heck... I'm only recording at 64 bits now!David Polich wrote:I found this lengthy discussion reminded me of a
here, of course):
at 32 bits?
